Power conditioner?
BjornB17
Hi guys,
I have an APC battery backup that i currently have all my stuff connected to. I was wondering if it also acts as a power conditioner, or if I should add one.
Are there any decent ones for under $150?
Thanks!
Thanks!
KEF Q150 | Rythmik F12 | Yamaha Aventage RX-A780
Post edited by BjornB17 on
This one is almost 75% off retail:
http://www.buy.com/prod/Monster_Power_HTS3500MKII_10_Outlet_PowerCenter_w_Stage_3_Filtering/q/loc/101/90119434.html -
It would depend on the model you have. Some of them do and some of them don't.
If you want to read alot of discussion on the subject go here .
It took me a long time to get through this thread but it had alot of good info.Skynut
SOPA® Founder
The system Almost there
DVD Onkyo DV-SP802
Sunfire Theater Grand II
Sherbourn 7/2100
Panamax 5510 power conditioner (for electronics)
2 PSAudio UPC-200 power conditioners (for amps)
Front L/R RT3000p (Bi-Wired)
Center CS1000p (Bi-Wired) (under the television)
Center RT2000p's (Bi-Wired) (on each side of the television)
Sur FX1000
SVS ultra plus 2
www.ShadetreesMachineShop.com
Thanks for looking
