Stand or Floor Mount CSi5??
I just ordered my CSi5 and need to know how to either put it on the carpet floor or with a short stand. My current center sits on my HDTV, but this speaker is to big. I know this speaker can be set on the floor to be angled up, but will I want to set it right on the carpet.
Onkyo TX-NR709 A/V Receiver
Polk RTi8's Front
In-Walls for Rears
CSi5 Center
SVS 20-39PCI Subwoofer
Post edited by reubenray on
The speaker should ideally be at ear level so putting it on the floor is not a good idea.
If you can build a shelf to hold the speaker great! If not then, get a stand for it.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
If your new center speaker is too big for your TV you might want to check out these:
Center speaker shelf/stand - Demo
Center speaker shelf/stand - Full PriceSony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15 -
DON'T PUT ON THE FLOOR. If is too big for your tv, use a stand...same as bookshelf's.My current new system (step by step )
A/V Receiver: YAMAHA RX-V657
DVD Player: YAMAHA DVD-S657
Main Towers: polkaudio® Monitor 50
Wiring: NeoTecH KS1007 OFC High Definition Speaker Cable ( 2 x 2.64 mm² ) -
How "deep" is your TV? If you can use that shelf, you can probaby use the support that comes with the speaker. I have the CSi5 and am using the long support it brings...works great._________________________________________________
I have a Sony Grand Wega 60" and right now I have my center on it. This speaker is heavier so was concerned with what damage it may do to my TV.
Polk RTi8's Front
In-Walls for Rears
CSi5 Center
SVS 20-39PCI Subwoofer -
There should not be a problem if you can support it decently well. if you look at the picture I posted, you probably can see in the front I added 10 of those vinyl self adhesive protective pads; gave stability and help distribute the weight._________________________________________________
The CSi speakers are designed to be "reversible" you can install it on the floor or under the TV if you had to. Rest the speaker on the sloped back section of the cabinet. This will angle the speaker towards your ears. you may need to add addition wedges as need to obtain the best angle required for your room.Proud SOPA Member since 2005!
nebborjk wrote:The CSi speakers are designed to be "reversible" you can install it on the floor or under the TV if you had to. Rest the speaker on the sloped back section of the cabinet. This will angle the speaker towards your ears. you may need to add addition wedges as need to obtain the best angle required for your room.
That is what I thought I read. Polk has a short shelf that I may use just to get the speaker off of the carpet. Will try the floor route first with something temporary before I decide.
Polk RTi8's Front
In-Walls for Rears
CSi5 Center
tryrrthg wrote:If your new center speaker is too big for your TV you might want to check out these:
What keeps the legs from sliding down the TV?
Polk RTi8's Front
In-Walls for Rears
CSi5 Center
