Mod Podge question
BullShifter
BullShifter Posts: 66
edited February 2006 in Speakers
The first thing I did to my subs was the Mod Podge with poly fill and it was a noticeable difference before replacing the speakers with Dayton's. My question now is how will Mod Podge affect a center channel speaker? I use a pair of JBL Sat 2's.
HK AVR 335
Polk R50 fronts
Polk CSi25 center
Polk R15 rear
2 Sony modded subs with 12" Daytons
32" Sharp Aquos
PS2
Post edited by BullShifter on
  • BullShifter
    anybody?
    HK AVR 335
    Polk R50 fronts
    Polk CSi25 center
    Polk R15 rear
    32" Sharp Aquos
    PS2
  • ohskigod
    ohskigod Posts: 6,502
    not much, well it depends on the speaker. its hard for anyone to say the effect it would have. physically it would add mass to the driver cone. this could be good (in the case of a sony wm500 sub, where it has been reccomended by many sources, or bad (particular driver with set mass is used for a reason)
    I wouldnt go experimenting unles they are throw away speakers, or there is documented good results. cant see mod podge adding much mass to smaller drivers anyway.
    Living Room 2 Channel -
    Schiit SYS Passive Pre. Jolida CD player. Songbird streamer. California Audio Labs Sigma II DAC, DIY 300as1/a1 Ice modules Class D amp. LSi15 with MM842 woofer upgrade, Nordost Blue Heaven and Unity interconnects.
    Upstairs 2 Channel Rig -
    Prometheus Ref. TVC passive pre, SAE A-205 Amp, Wiim pro streamer and Topping E50 DAC, California Audio Labs DX1 CD player, Von Schweikert VR3.5 speakers.
    Studio Rig - Scarlett 18i20(Gen3) DAW, Mac Mini, Aiyma A07 Max (BridgedX2), Totem Mites
