Amp pricing & diminishing returns / what's your take?
pearsall001
pearsall001 Posts: 5,093
edited February 2006 in Electronics
I've been looking at a few amps for my system to run in both HT & 2 channel listening. My source is a Consonance Droplet5.0 tube output player, NAD T773 receiver as pre/pro, AADaudio 2001 monitors (8ohm, 86db sensitivity) The amps in question are: Mac MC252, Bryston 4BSST, NuForce ref 9, Rotel RB1090. Prices new are: Mac-$3800, Bry-$2800, NuForce-$2500, Rot-$1800. As you can see that's a pretty big pricing gap. My question is about the sonic qualities between them & if some really warrant the extra coin? For example the diff in price between the Mac & Rot is $2000. Does the Mac bring $2000 more musicality to the table than the Rot or even the others? At what point does the scale start to tip downwards in regards to cost/performance ratio? I haven't included Krell, Classe, ML because I believe the scale really starts to dip downwards with them. Maybe I'm off base here but I am open for suggestions & your comments. Warranties (although important) re-sale pricing, braging rights etc. would not be a deciding factor in my purchase. I really don't like buying used either, I prefer new.
Post edited by pearsall001 on
    heiney9 Posts: 25,217
    As Early B said in a very recent post of mine. Prices don't mean a damn thing in Audio.
    No one really knows. According to the latest issue of Stereophile the new Outlaw receiver at $500 is excellent when paired with $125,000 worth of speakers and front end equipment.
    Listen and look for system synergy regardless of price. I'm sorry there just isn't a concrete answer to your question, IMO. :confused::confused::confused:
  • steveinaz
    steveinaz Posts: 19,538
    Buy the Rotel and take your woman to Maui with the money you saved. You'll get a hell of an amp, and "I owe you" sex for years to come...
  • Early B.
    Early B. Posts: 7,900
    It's hard to say where diminishing returns kick in. I think it depends a lot on your budget, not your ear. For me, diminishing returns for a 2-channel SS amp kick in at around the $350 mark (used). However, if I had more money to spend, I'd set the bar for diminishing returns at a much higher level, not because it necessarily sounds better, but due to other reasons such as brand, looks, bragging rights, cutting edge, rarity, exclusivity, etc. In other words, I'd buy a more expensive amp simply because I could afford to do so.
    Don't worry about diminishing returns. First, I come up with a budget, then shop for the best component within that budget.
    "God grooves with tubes."
  • thehaens@cox.net
    thehaens@cox.net Posts: 1,012
    Good Points E.B. most of us started with a hand me down, at least I did, and then worked up from there, saved some money, bought up. Eventually everyone will outgrow what they have, and want more. I keep saying, (well I justify it with the wife), that this will be the last amp or pre, that we are going to need. But somehow there is always a "deal" to be had..
    Scott
  • 2+2
    2+2 Posts: 546
    I think that is right on....for me my sig is where I "perceive" the diminishing returns to occur...my target was the border of what constitutes "midfi" and "hifi"...
    You seem to target a bit higher...good for you.
    Steve also has a great idea...unless you have disposable income up the wazzoo, you may want to spend it elsewhere to make some lasting memories with your loved ones....(my interpretation of what Steve is saying).
    System 1: Martin Logan Vantage, Rotel RC 1070, B&K Reference 200.2, Music Hall DAC 15.2, Yamaha 2300
    System 2: LSi15 w/db840, Marantz SR8400, Rotel 1080, RM6800 (C&S), Sony X2020ES
    System 3: LSi7, Yamaha SW215, Music Hall Maven, Music Hall MMF CD25 w/627opamps
    System 4: RTi100, Harman Kardon AVR 230, Panasonic DVD
  • steveinaz
    Yep. The Rotel is a hell of an amp, I don't think the increase in cost to the others will justify itself. Once you hit a certain level in amps, differences become minimal very quickly. I personally will never go above $1800 for amp, period. The rest is fluff & fold as far as I'm concerned. I'll be running my $950 Parasound until it smokes...
    But that's my opinion.
  • Hawkeye
    Hawkeye Posts: 1,313
    I'd think about resale value. Everybody here has the upgrade fever. I bought a Mcintosh MC352 mint from a dealer for $3600.00. I know from research of this piece, that if, actually when I upgrade, I'll get real close to what I paid if not more at trade in or sell time. I can't say that about some of the other amps I've owned.
    I have a B&K Ref 220 I paid $1200.00 for which the Mac replaced. I bet nobody here would give me $1200 for the B&K. There is no comparison in the slam in the bottom end, and the highs and mids are awesome with the MAC.
    I believe your amp is the heart of a system. You gotta hear em to make the call.
    2 Channel -
    Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8)
  • scottyf
    scottyf Posts: 129
    I also thought my well engineered, solid state amps were good enough. Until my most recent aquisition, the most I'd spent on a single amp was $800 (I got a Perreau and a Threshold at that price, used of course.)
    Then I got my Counterpoint modified (the amp cost $400 on ebay). I have a little over 3k in that bad boy now and it has changed what I thought stereo could sound like. Really amazing.
    I'm not saying that you should go out and get one like mine (secretly I do), but rather that there are amps out there that make more of a difference than you can imagine. At least that's what I found. The trick is to listen to them and if you find that kind of amp, you don't mind spending the extra money.
    Until you find that amp, Rotel makes a pretty nice one.
    Also, if you buy used, your gear will hold it's value much better if you want to turn it.
    HOME: VPI Classic/Grado Reference Master, EVS-modified Oppo BP83, Bryston DAC, Counterpoint 3000/SA-100 modified by Alta Vista, Polk LSi15
    TRUCK: Pioneer 8600MP, Soundstream 300SX, pr of Xtant 1001i, Autotek SS490.2, Polk SR6500, Polk MMC6500, pr of Polk MM2084DVC
  • unc2701
    unc2701 Posts: 3,587
    Since you've ruled out a lot of the major things to consider, (resale, warranty, buying used, etc) then the only thing left is for you to listen. Obviously I thought the $1k from rotel to bryston was worth it... but the $1k on up to Mac wasn't. In part, my choice was based on the resale & warranty (I told the woman that if we had a kid, he could take the 4b to college with him), but you gotta decide waht matters to you & hear them.
    Backburner:Krell KAV-300i
