Dedicated Circuits
cewolcott
cewolcott Posts: 20
edited February 2006 in Electronics
Question:
How many dedicated circuits/type do you have for your system?
___ 15A
___ 20A
How do you seperate your gear across the circuits?
If you use a power conditioner/surge do you save one or more across the individual circuits? If not what gets plug into the conditioner.
Post edited by cewolcott on
  • Skynut
    Skynut Posts: 2,967
    Everything I have goes through my power conditioner.
    I want to get a dedicated 20 amp outlet but that is going to have to wait.
    Skynut
    SOPA® Founder
    The system Almost there
    DVD Onkyo DV-SP802
    Sunfire Theater Grand II
    Sherbourn 7/2100
    Panamax 5510 power conditioner (for electronics)
    2 PSAudio UPC-200 power conditioners (for amps)
    Front L/R RT3000p (Bi-Wired)
    Center CS1000p (Bi-Wired) (under the television)
    Center RT2000p's (Bi-Wired) (on each side of the television)
    Sur FX1000
    SVS ultra plus 2
    www.ShadetreesMachineShop.com
    Thanks for looking
    F1nut Posts: 51,770
    Adamstown, eh? I almost bought that big stone house across the tracks from the PO.
    When I'm finished getting things done around here it will be one dedicated 20 amp line per piece with a UPC-200 for each piece.
  • cewolcott
    cewolcott Posts: 20
    The one with all the Confederate Flags? Do you still live in the area? We bought into the Green Hill Manor (Ausherman community) 6 years ago.
    F1nut Posts: 51,770
    It was the only stone house in town that I was aware of, but there were no Confederate Flags when I looked at it. I'm closer to the Woodbine area now.
  • I-SIG
    I-SIG Posts: 2,243
    I'm planning to add a 40A breaker in my last remaining spot, install #6 so I can run a 60A in the future, add a subpanel with (2) 20A breakers for two 20A outlets.
    Wes
    Link: http://polkarmy.com/forums
    Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d
  • jmierzur
    jmierzur Posts: 489
    I have two installed in my room; one 15 amp and one 20 amp. I use the 20 amp line to power my entire system using a BPT BP-2.5 balanced power conditioner.
    If your total system power draw is less than 2400VA, have you considered installing one 20 amp dedicated line for your entire system and use a BPT BP-2.5 Ultra balanced power conditioner. If budget has not expired, you might want to consider the addition of the Bybee Quantum Purifiers (BQP) and the HFC-30 differential noise filter.
    I have a dedicated 20 amp line supplying a BP-2.5 with the BQP and HPC-20 (legacy version of HPC-30) options powering my entire system. Read the reviews of the BPT units to get an understanding of what to expect when using balanced power.
    I had tested the PSA Ultimate Outlet in my system and found the BPT unit to be much superior. As we do not have a local PSA dealer anymore, I have not tested the UPC-200, nor have any desire to.
    To achieve further gains (if within budget), how about a BP-3.5 Signature or Signature Plus unit. Read the 6moons review of the Signature unit as well as the Signature Plus update.
    If you are set on seperating components, I would suggest that you run analog components through the 20 amp circuit using a BP-2 or BP-2.5 or BP-3.5 series unit and digital components through a 15/20 amp circuit using a BP-1 / BP-10.5.
    You might want to test powering the entire system through the larger transformer before seperating the analog and digital components.
    Have I spent enough of your money yet?? I have another suggestion that I have not verified yet. With a little luck, it will happen later this year.
    I hope you seriously consider this option.
    Let us know at some point what you decide to do.
  • audiobliss
    audiobliss Posts: 12,518
    hmm...very nice looking setup that guy has...
    Are those Dodd Audio monoblocks?
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • unc2701
    unc2701 Posts: 3,587
    I've got two 15amps and a 20amp.
    The 5 channel (2300watt max draw) 9B goes on the 20amp; the 4b goes on one 15amp and the rest goes on the other 15amp.
    In the new place I'll probably do what I-Sig has in mind- pull a bigass line up to the unfinished attic and put in a subpanel- Might do an independent ground for it at the same time.
    Backburner:Krell KAV-300i
  • amulford
    amulford Posts: 5,020
    Right now I have two 20's to the HT. I'm going to put in another 20 and a 30 in another room shortly.
  • Grimster74
    Grimster74 Posts: 2,577
    I have (2) 20 amp circuits, one for a/v equipment and one for the SVS.
  • Ron-P
    Ron-P Posts: 8,520
    I run two 20 amp.
    If...
    Ron loves a film = don't even rent.
  • RuSsMaN
    RuSsMaN Posts: 17,986
    1 20amp to each listening room (2), 1 20amp to the HT room.
    Balanced power supplies will be the final step for me, power wise.
  • Gaara
    Gaara Posts: 2,415
    1 20 amp directly to my Cinenova
    1 20 amp for most everything else
    1 15 amp that has lights on it, two clocks, and my buttkicker amp
  • wingnut4772
    wingnut4772 Posts: 7,519
    I have one dedicated 20 (now I wish I had put two!) and I have it just for my pre and Cinenova. Everyrhing else is on 15s that came with the house through my Monster 2500 except for the SVS which is on a 15 by itself with a Harmonic Technology power cord.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
