knu knanners knot knice
dragon1952
dragon1952 Posts: 4,907
edited February 2006 in 2 Channel Audio
I just replaced my cheapo gold plated nanners on my amp end with some KnuKoncept BFA gold plate over berrylium copper nanners and my system has lost every ounce of musicality it seems like. What up with that? These suckers fit tighter than a 14......well really tight anyway. I had to really push them in and they're supposed to give more surface contact area, etc. The old nanners fit kinda loose . I didn't really expect a change in sound for better or worse. Just looking for a better fit. This really sucks though. These suckers gotta break in or something?
Post edited by dragon1952 on
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    They look like some type of fancy fruit coring tool. It is kinda late, maybe your ears are tired.......I've decided to go locking bananas on my next cable.
  • scottyf
    scottyf Posts: 129
    It's all about synergy. Your system liked the ones you had before better than the new ones. That's why you have to actually listen to components.
    That type of thing happend to me recently. I had swapped out a pair of Musical Concepts cables for a pair of JPS Superconductors because I was trying to get a change in bass. The Superconductors were wonderful between my CJ Premier 14 preamp and Perreaux 2150B amp, but between my current Counterpoint stuff, I found myself getting bored with the music. Interestingly, everything sounded great, but it just didn't have the "draw you in" ability.
    Swapped cables back and all was well. Synergy!
    HOME: VPI Classic/Grado Reference Master, EVS-modified Oppo BP83, Bryston DAC, Counterpoint 3000/SA-100 modified by Alta Vista, Polk LSi15
    TRUCK: Pioneer 8600MP, Soundstream 300SX, pr of Xtant 1001i, Autotek SS490.2, Polk SR6500, Polk MMC6500, pr of Polk MM2084DVC
  • scottyf
    scottyf Posts: 129
    Or what Dennis said.
  • dragon1952
    LOL! Guess I'll have to reread the ad. All I saw was the word 'banana'. Guess I just had audio on my mind at the time. How embarrasing :o
  • Dennis Gardner
    They are made for the Island of Knu where apples only grow to the size of quarters, but have 10 times the flavor of Washington's best offering. ;)
    Good night Dragon......
    F1nut Posts: 50,723
    Interesting problem. The only thing that comes to my mind is to can those suckers and try something else.
    Wait a sec....did you solder the wire to the posts or are the wires held in with screws?
  • dragon1952
    I still have the old ones. I'll give these a few more days and see what happens. No, these aren't soldered. They're like my old ones in that they use a set screw except they have 2 set screws vs just one. In all regards these new ones should be better. BTW, I have been very tired the last couple days . Maybe it's just a coincidence and I just don't have my good ears on.
    F1nut Posts: 50,723
    I've not heard of nor experienced burn in for connection devices. Maybe try soldering the wires to the banana's.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    Hmmm............take em off, go bare wire and see if the magic comes back. I think they will work well for holding an ear of corn if nothing else.
    RT1
    F1nut Posts: 50,723
    Excellent idea, both of them!
  • audiobliss
    audiobliss Posts: 12,518
    I would have to question if you accidentally changed anything else during the transition. I wouldn't think banana plugs would have that much of an affect one way or another, especially such a bad effect when switching in much more solid ones.
    I'm not sure what else could have changed, though. Maybe another connection got loose, the wires aren't in good/screwed down good in the bananas, etc.
    :confused:
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • Skynut
    Skynut Posts: 2,967
    I think it is the metalurgy. "gold plate over berrylium copper" Perhaps the berrylium is not a good conductor or lends itself to alter the signal?
    Skynut
    SOPA® Founder
    The system Almost there
    DVD Onkyo DV-SP802
    Sunfire Theater Grand II
    Sherbourn 7/2100
    Panamax 5510 power conditioner (for electronics)
    2 PSAudio UPC-200 power conditioners (for amps)
    Front L/R RT3000p (Bi-Wired)
    Center CS1000p (Bi-Wired) (under the television)
    Center RT2000p's (Bi-Wired) (on each side of the television)
    Sur FX1000
    SVS ultra plus 2
    www.ShadetreesMachineShop.com
    Thanks for looking
  • reeltrouble1
    I am getting uranium nanners. You plug them into ur anium and you glow, might not sound that good butt I bet you feel all warm and fuzzy.
    RT1
  • steveinaz
    steveinaz Posts: 19,538
    Cables and connectors can do strange things, I don't understand it, so I won't try to explain it. Let them run for a week or so, if you don't like them, go back to your original setup. I have had some similar experiences with cable/connector changes. It's beyond the scope of my brain....
  • dragon1952
    Synergy....metalurgy....strange things that go bump in the night..... all things you might experience...as you enter....the Twilight Zone.
    I am back to the original nanners and all is well. I actually tried another set I had laying around and got back the sweet sound w/out as much air as the originals but I can honestly say I heard the difference in all 3 sets. I swear I did. I have tried all kinds of connections before on other systems...bare wire, bananas, spades and never , ever heard a difference before. This is the first time I've changed anything with this current system though but still I just don't believe it and you probably won't either.
