computer question (memory-related)
neomagus00
okay, i searched for an answer to this, and couldn't find one, so i figured i'd ask the computer people here for a pointer (hehe) in the right direction...
i run winXPpro, and i have a little program called ObjectDock that basically replicates mac OSX's dock (hides itself when not in use, pops out of the edge of the screen on rollover), i like it a lot... problem is, if i don't use it for a while, it gets paged to disk, and then when i rollover it next, it takes a sec to reload all the images... is there any way to tell XP to keep this particular process in true RAM all the time, and not to put it to the pagefile?
if no one knows the answer, are there any good computer forums out there i can search on?
thanks...
thanks...
