Speaker Stand for Polk FXi3?
What stand will work for these speakers? The shape is different than most speakers.
Onkyo TX-NR709 A/V Receiver
Polk RTi8's Front
In-Walls for Rears
CSi5 Center
SVS 20-39PCI Subwoofer
Post edited by reubenray on
Seems to me the best option is to wall mount them... Ideally they should be about 6' or more high and youll have a hard time finding a stand like, even then it would look silly.-Stopher
Tempe, AZ
Setup:
Polk RTi8 Mains
Polk CSi5 Center
Polk FXi3's Surround
Cerwin Vega HTS10 Subwoofer
Yamaha HTR-5740 AVR
Upstairs R50/R15/CS1 5.1 setup w Pioneer AVR -
Where I will be using them is a rented house and there is not wall where I want them to be at.
If they are not stand mountable I may get something else (RTi6) instead.
Has anyone put these speakers on a speaker stand???
Polk RTi8's Front
In-Walls for Rears
CSi5 Center
SVS 20-39PCI Subwoofer -
Ideally this speaker needs to be mounted about 3' above the listener's ear level. You're looking are about 6' off the ground in most cases. I don't know of any speaker stands this tall. Check out the DIY section of the forum. There's probably a post or two about building your own, if your so inclined.
I'd wall them mount irregardless.Proud SOPA Member since 2005! -
OK which wall mounts works the best with the FXi3? Will have to redo some wiring.
Polk RTi8's Front
In-Walls for Rears
CSi5 Center
The Fxi3 has a mounting bracket/plate on the back of the speaker. All you'll need is a screw if you can find a stud or a hollow wall anchor if not.Proud SOPA Member since 2005!
