Problem with SRS 1.2
StarlightWk
Hi,
I am currently facing problem with my SRS 1.2 . I face intermittent for
the bass on the left speaker most of the time. It just goes off but the
tweeters will just be sounding. What I did was apply pressure on the
banana plugs to the binding posts and the bass came back on . I
thought was some loose connections of the speaker wire on the banana
plugs, but it wasn't the case. They were screwed on tight without doubt.
Anyone face similar problem as I did ? How do I solve this ? Appreciate
the help , thanks .
the help , thanks .
Post edited by StarlightWk on
Are your 1.2's bi-wired or single with jumpers?
If single, are you going into the upper or lower pair of speaker posts?More later,
Tour...
Vox Copuli
