Vintage turntable hookup
jakelm
jakelm Posts: 4,081
edited February 2006 in Vintage Speakers
I know this is not the ideal place for this question, but I know alot of you have vintage equipment beyond speakers.
I have inherited a vintage Lin Sondek turntable I am dying to hook up and listen to on my vintage 7b's. The problem is that my Onkyo A\V reciever has no phono inputs or ground. How can I hook this up properly?
Can I hook the ground to a screw on the chasis and use cd input?
Jake
Monitor 7b's front
Monitor 4's surround
M10's back surround
Harman/Kardon AVR-635
Oppo 981hd
Denon upconvert DVD player
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Dont BAN me Bro!!!!:eek:
  • seo
    seo Posts: 305
    You need a phono preamp. The signal is too low for the inputs on your receiver.
    You need something LIKE THIS
    Signature goes here
  • jakelm
    jakelm Posts: 4,081
    Thanks for the info Seo. I figured as much, but was hoping not to have to buy another peice of electronis. :p
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • jakelm
    jakelm Posts: 4,081
    I know of NAD. Would you know if BBuy or CCity sells anything I can use?
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • jakelm
    jakelm Posts: 4,081
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • RuSsMaN
    RuSsMaN Posts: 17,985
    Yes, that would work.
  • nadams
    nadams Posts: 5,877
    Well, yes... but that really wouldn't sound as good as the NAD..
    Ludicrous gibs!
  • seo
    seo Posts: 305
    NAD PP-2
    You could also look for an old 7020 receiver, or 3020 int amp from NAD. Should be able to pick one up for less than a $100
    Signature goes here
  • jakelm
    jakelm Posts: 4,081
    I have an old HK 330c I can use, I just remebered.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • jakelm
    jakelm Posts: 4,081
    Thanks all for your input. I hope that 330c works well. I'll just loop from phono in to tape out then to tape in on my Onkyo
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    heiney9 Posts: 25,651
    As Russ says it will work, but the Linn is a nicer table (assuming it's in good cond. w/a good cartridge) than that GE phono-amp. Parasound makes a nice unit you can get fairly cheap P/PH-100 here's a link. It appears the P/Ph-100 is sold but he has another Parasound f/s also. This will do a much better job than the GE, it's up to you how far you want to go. The GE will not do the Linn justice, IMO
    http://cls.audiogon.com/cgi-bin/cls.pl?preaphon&1144461305
    FWIW
  • jakelm
    jakelm Posts: 4,081
    I'm not getting the GE, your right, only as good as your weakest link. I'll just try to loop it thru my HK reciever and see if that would work.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • TroyD
    TroyD Posts: 13,124
    That is a NICE table (hint, if you ever care to part with it, I'd have more than a passing interest)......the NAD is a nice phono pre, there is a new tube phono pre going for peanuts, belari, or some such that is getting a LOT of good press.
    BDT
  • jakelm
    jakelm Posts: 4,081
    My Father had this Lin Sondek hooked to (I forget the model) 1970's Infinity pre amp and 200w\2ch Hafler amp, to his stacked Monitor 7a's. The Infinity preamp had a metal case with a blue face, blue lights and big silver knobs (if anyone could help me remember the model). It also has a matching amp. The amp's power supply went out so he hooked the Hafler amp in its place. One of the best sounding system I've ever heard. Everything was kept in mint condition and I believe I have a working cartrige on the table itself and a replacement cartridge in a box also.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • jakelm
    jakelm Posts: 4,081
    Ahaaahh I found the Infinity preamp I was talking about. The amp that went out was the matching amp. http://cgi.ebay.com/1976-Infinity-FET-Preamplifier-BROCHURE_W0QQitemZ5823461800QQcategoryZ50594QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • jakelm
    jakelm Posts: 4,081
    And here is the amp http://cgi.ebay.com/1976-Infinity-DSP-Switching-Amplifier-BROCHURE_W0QQitemZ5823461265QQcategoryZ50594QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
    Now I know the "I" word is a bad word here, but thiese 2 pieces with the Linn Sondek table and the stacked 7a's, were truely unbelievable.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • jakelm
    jakelm Posts: 4,081
    This looks like the exact table I recieved. If its from the late 70's, its the same one.http://cgi.ebay.com/Linn-Sondek-LP12-Turntable-wLinn-Ittok-LV-II_W0QQitemZ5667193075QQcategoryZ31411QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
    I cant believe I found picture online of these very old and rare peices.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • jakelm
    jakelm Posts: 4,081
    The only difference is my table has the smoked bronze cover, not the clear cover
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • ward91
    ward91 Posts: 338
    the linn things are v good from what ive heard.
    ELECTRONICS
    arcam cd93
    linn wakonda
    MC2 MC450
    Teac ud h01 DAC
    SPEAKERS
    Tannoy DC6 t se .
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    I would recommend getting our members's Madmax Jolida 9a he has for sale in the Flea Market.
    I would bump the thread but not sure if I can anymore. Anwyay as BDT mentioned the Belarri or the Jolida, the Bellari costs a bit less but does not have quite the build quality of the Jolida and since their name is not as established and so on.
    The Jolida is a solid unit and going to be with you for a while.
    RT1
  • shack
    shack Posts: 11,154
    There is stuff all over the internet about this TT...
    Stereophile
    Audio Revolution
    TNT-Audio
  • jakelm
    jakelm Posts: 4,081
    Thanks Shack, but it was the Infinity amp and reamp that is so hard to find.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
