DVD Player Upgrade
kmartin971
I am looking for a solid DVD player. I have owned a Pioneer Elite for around five years and am looking to upgrade. MY 65" Mit accepts only component video for 1080i. Any one know if a solid DVD that upconcerts using a componet video out?
TV = WS65611
Pre-Amp Onkyo 830
Amp Aragon 2007
Panamax 5510
Towers = LSi25s
Center = LSiC
Side Rear (2) = LSiFX
Rear (2) = LSiFX
JBL S120P II
Sony Upconverting DVD Player
XBox
XBox 360 (Wireless connection live and media center enabled)
PS3
Pre-Amp Onkyo 830
Amp Aragon 2007
Panamax 5510
Towers = LSi25s
Center = LSiC
Rear (2) = LSiFX
JBL S120P II
XBox
PS3
Post edited by kmartin971 on
Nope. Most of the decent or "solid" upscaling players only output the 1080i through the HDMI or DVI outputs. There was a mediocre Zenith model that was able to upconvert through component video, but only if you reverted it back to an older firmware. That said, you won't really see much improvement by upscaling anyway, especially if your TV is CRT based. Its probably not a good idea to upgrade for that reason alone.
Does the Mits have more than one native resolution?
Yes. It have seperate inputs for 480i, 480p, and 1080i. Looks like I will just have to buy a new TV!TV = WS65611
Pre-Amp Onkyo 830
Amp Aragon 2007
Panamax 5510
Towers = LSi25s
Center = LSiC
Rear (2) = LSiFX
JBL S120P II
XBox
PS3 -
Native resolution is what the TV actually displays. For instance, my Hitachi can display 540p or 1080i natively.
Link to the manual is in my signature.TV = WS65611
Pre-Amp Onkyo 830
Amp Aragon 2007
Panamax 5510
Towers = LSi25s
Center = LSiC
Rear (2) = LSiFX
JBL S120P II
XBox
PS3 -
I can't see your signature. What's your model number?
WS65611. It's under his first post. In case you can't see it there, here's the link:
HEREGeorge Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Pioneer Premier DEH-P860MP, Memphis 16-MCA3004, Boston Acoustic RC520 -
Hard to say from the manual, could possibly be 480p and 1080i, get on a Mits Forum to find out for sure. If you are lucky to have native 480p then don't waste your time upscaling/"upconverting", get a DVD player with a good deinterlacer and output at 480p, you'll have a great picture. Go Denon.
I actually searched and search for one of those a little while back to no avail. I even looked into a seperate up-converter, and nothing seemed that it would give "good" HD picture. Ended up going with the Denon 2910 (it upconverts via HDMI). But I do have to say, even without an upconvert, the picture is leaps and bounds over my old toshiba.Denon AVR-3803
RTi-70 Fronts
FXi-30 Surrounds
RTi-38 Back Surrounds
Csi-40 Center
PSW350 Sub
Panasonic PT-56WXF95 HDTVSamsung un60JS8000 SUHD
Denon DVD-2910
Xbox, Gamecube, PS2, PS3, PS4, xbox360, Wii, WiiU, n64 -
The native resolution is the maximum pixels or picture elements. You cannot exceed this. 480p is DVD's native resolution. So, if you output DVD progressively (480p), your TV will scale it to fit your pixels (line doubling, scaling) You won't get a 1080 picture from a 480 source. Not even with a Faroudja scaler can you get orange juice from apples.
Get a true bit by bit progressive DVD player and plug it into the 480p input with good component cables.-Ignorance is strength - -
kmartin971 wrote:I am looking for a solid DVD player. I have owned a Pioneer Elite for around five years and am looking to upgrade. MY 65" Mit accepts only component video for 1080i. Any one know if a solid DVD that upconcerts using a componet video out?
Martin,
The Oppo player is adding the ability to upscale via Component video in March. If you are not in much of a hurry, I would highly recommend waiting and picking up this great player.
http://www.avsforum.com/avs-vb/showthread.php?t=643373Holydoc (Home Theatre Lover)
__________________________________________
Panasonic -50PX600U 50" Plasma
Onkyo -TX-NR901 Receiver
Oppo -Oppo 980HD Universal DVD Player
Outlaw -770 (7x200watt) Amplifier
PolkAudio - RTi12 (Left and Right)
PolkAudio - CSi5 (Center)
PolkAudio - FXi3 (Back and Surround)
SVS - PB-12/Plus (Subwoofer)
Bluejean Cables - Interconnects
Logitech Harmony 880 - Remote -
I know it's LG but I thought I saw an LG which claims to upconvert with component
LGDVB418
On page 10 of the manual,You can change the resolution (480i, 480p, 720p,
1080i) for the component/progressive scan video
output by pressing RESOLUTION on the front
panel.
For 720p and 1080i resolution, only non-copy
protected discs can be played back. If the disc is
copy protected, it will be displayed at the 480p
resolution.
HDMI mode must be set to OFF for Component
video connections.
Progressive scan does not work with the analog
video connections (VIDEO OUT & S-VIDEO).
So yes, it will do upconversion through component video output, but the disc can't be copy protected.Tschüss
Zach -
okiepolkie wrote:LGDVB418
Thanks OP. I knew I was dreaming when I saw that. So is a burnt or downloaded movie copy protected ? -
I'm not sure about those Willow? Maybe someone else might know that answer.Tschüss
Zach -
Willow wrote:Thanks OP. I knew I was dreaming when I saw that. So is a burnt or downloaded movie copy protected ?
if you burn a copy, you should have already bypassed the copy protection..or else it wouldn't have copied...
I think the real problem would be any kind of compression that was used when you copied the movie...if you only use single layer blank dvd's, chances are the movie would have some compression so it would fit onto the single layer disk...this would definately affect resolution...don't know how much..butPioneer Elite VSX-53, Polk RT800i fronts, Polk CS400i center, FX500i surround, Velodyne sub -
I have seen this before and basically it looks like it makes the movie older. Like it was shot to look older and I guess grainy and a little dimmer. Thats what I noticed but its not too terrible but you would not want all your movies to look like that.Harman Kardon AVR635
RTi10's Up Front
CSi5 Center
RTi6's Rear Surround
Furman RA-1210:rolleyes: -
Most of my burnt movies are full DVDs if need be I'd buy a dual layer dvd. Never have i noticed my copies dark or grainy
Sorry, need to be more specific..... This was a single layer DVD as mentioned above that came from a friend from a friend off the internet before the movie was released out on DVD.Harman Kardon AVR635
RTi10's Up Front
CSi5 Center
Onkyo has the DV-sp1000 that has HD compnent outputs, but you are talking about$2000.00.
you can check it out here.
http://www.onkyousa.com/model.cfm?m=DV-SP1000&class=DVD&p=i
http://www.crutchfield.com/S-FCqn6r3MAyV/cgi-bin/ProdView.asp?g=54400&id=morephotos&pi=2&i=580DVSP1K&display=XL#Tab -
As soon as Blu Ray comes out existing DVD player prices are going to drop like bricks! You can pick up a denon 2910 on ubid.com for $500.TV = WS65611
Pre-Amp Onkyo 830
Amp Aragon 2007
Panamax 5510
Towers = LSi25s
Center = LSiC
Rear (2) = LSiFX
JBL S120P II
XBox
PS3 -
There is always Neodigits as well.
http://www.neodigits.com/new/body/products/HVD2085/overview.asp
-Lou -
Interesting Lou, I thought everybody stopped using upscaling through component video.
Could wait for the HD-DVD players. I think there is the possibility of having 1080i component out. I saw that somewhere, but I think its under debate.Brian Knauss
ex-Electrical Engineer for Polk -
kmartin971 wrote:signature: ... (Wireless connection live and media center enabled)Win7 Media Center -> Onkyo TXSR702 -> Polk Rti70
Anybody knows the Yamaha S-2500 dvd player ???? It's good ???My current new system (step by step
A/V Receiver: YAMAHA RX-V657
DVD Player: YAMAHA DVD-S657
Main Towers: polkaudio® Monitor 50
Wiring: NeoTecH KS1007 OFC High Definition Speaker Cable ( 2 x 2.64 mm² ) -
bknauss wrote:Could wait for the HD-DVD players. I think there is the possibility of having 1080i component out. I saw that somewhere, but I think its under debate.
Just to follow up on my own post, Crutchfield claims no HD output over component on the upcoming Toshiba HD-DVD players.
On the other hand, I now do remember Samsung has some older models that you can put a remote code into and it will do upconverting over component. I believe its model # HD851. avsforum.com is the best source for that stuff.Brian Knauss
