Need Receiver Choice Help??
reubenray
reubenray Posts: 91
edited February 2006 in Speakers
All alone I was planning on getting a Yamaha 5890 receiver to match my soon to be ordered Polk speakers. I keep reading about the sound being "Bright".
I have come up with 2 alternates.
1) H & K AVR-435 ($75 more)
2) Onkyo 703 ($119 more)
Any suggestions is appreciated.
Onkyo TX-NR709 A/V Receiver
Polk RTi8's Front
In-Walls for Rears
CSi5 Center
SVS 20-39PCI Subwoofer
Post edited by reubenray on
  • aaharvel
    aaharvel Posts: 4,489
    if you don't like bright sound, then H/K all the way. IMO Onkyo is just as bad as Yamaha when it comes to this.
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
  • reubenray
    reubenray Posts: 91
    I do not know if I like bright sound or not. I do not know what "Bright" means.
    Polk RTi8's Front
    In-Walls for Rears
    CSi5 Center
  • Willow
    Willow Posts: 11,058
    1) H & K AVR-435 ($75)
    2) Onkyo 703 ($119)
    75$, for the 435 ? :eek: are you getting just the metal case ?
  • reubenray
    reubenray Posts: 91
    No $75 more than the Yamaha!!
    Polk RTi8's Front
    In-Walls for Rears
    CSi5 Center
  • *Seby*-Polk-
    *Seby*-Polk- Posts: 375
    Listen music with both receivers and choose. I like the sound little bright than normal..for that reason I buy a Yamaha receiver that sounds great (for movies and music).
    If you don´t like bright sound...I recommend a Denon A/V receiver instead of HK.
    Bye
    My current new system (step by step :D)
    A/V Receiver: YAMAHA RX-V657
    DVD Player: YAMAHA DVD-S657
    Main Towers: polkaudio® Monitor 50
    Wiring: NeoTecH KS1007 OFC High Definition Speaker Cable ( 2 x 2.64 mm² )
  • 2Learn
    2Learn Posts: 28
    Yamaha or H/K.
    The latter is my choice although I am setting up a Marantz.
  • reubenray
    reubenray Posts: 91
    Do all of these receivers have sufficient power for the speakers?
    Polk RTi8's Front
    In-Walls for Rears
    CSi5 Center
  • texastbird
    texastbird Posts: 16
    I'm brand new to HT, but I went with the Yamaha, mainly for the price. I got it at Etronics.com. I've heard they might not be an authorized dealer and I'm not sure about what that means warranty wise. But I like the sound of the Yamaha just fine and the features are easy to figure out after you read the manual a few times. Playing music on the same speakers compared with my old Pioneer stereo receiver, I could understand that it indeed may sound a little brighter. But to my tired old ears, I think the dialogue in movies comes through well. Very unscientific, but if you go to the BB or CC store, its hard to tell much from their setups anyway.
  • cfrizz
    cfrizz Posts: 13,415
    Both will get the job done, and both have preouts so that if you decide you need more power you can get separate amps.
    You will only know which one you like when you go & listen to both with your own music that you know very well.
  • *Seby*-Polk-
    Yes..agreed with other posts. You may decide by yourself and yoour ears :)
    At this level...Yamaha and Denon are the best brands in the whole world (with Marantz and HK) in a/v receivers. The sound is crystal clear in all of them. Choose for your feelings ;)
  • zombie boy 2000
    zombie boy 2000 Posts: 6,641
    :) what speakers do you have on order?
    different brands pair better (or worse) with certain models
  • *Seby*-Polk-
    Yes..it's true. For me, Denon receivers sounds better with RTi speakers than Monitors.
    Pay atention !!!!
