filling speaker stands?
just to refresh, I got some Dayton speaker stands that I can fill. I was going to use sand? but should I use sand and lead shot?
I was thinking just put lead shot on the bottom (lower center of gravity) then cap off with sand.
any thoughts? never filled stands before.
got these to put under the LSi9's I'll using while I tweak the Carver's
Living Room 2 Channel -
Schiit SYS Passive Pre. Jolida CD player. Songbird streamer. California Audio Labs Sigma II DAC, DIY 300as1/a1 Ice modules Class D amp. LSi15 with MM842 woofer upgrade, Nordost Blue Heaven and Unity interconnects.
Upstairs 2 Channel Rig -
Prometheus Ref. TVC passive pre, SAE A-205 Amp, Wiim pro streamer and Topping E50 DAC, California Audio Labs DX1 CD player, Von Schweikert VR3.5 speakers.
Studio Rig - Scarlett 18i20(Gen3) DAW, Mac Mini, Aiyma A07 Max (BridgedX2), Totem Mites
Post edited by ohskigod on
It depends on how much weight you'd like to add. Lead shot, of course, is much heavier than sand. Unless you've got a huge fillable area sand doesn't really add all that much weight but it's better than nothing. You could use coins and make a piggy bank out of them. Kitty litter has also been mentioned, as when my poor Sparkles disappeared leaving a shitload of kitty litter in his wake, no puns intended Having said that, I just used sand in mine and I think it worked fine.2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones
Audio Advisor carries some stuff called Apollo Sound Bytes. Made of small stainless discs. 22 lbs for $49. I don't see it on their website but it is in the new catalog page 27.
Lead shot is king in my book. 25lbs. for $20.00 at any Pro Bass Shop, probably at Wal-Mart too. Use heavy latex gloves when handling.Political Correctness'.........defined
President of Club Polk -
I concur with the lead shot idea, it's not that expensive.
Heavy gloves when handling? Thanks Mr. Safety.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
I have some PE stands and filled them with sand. It didn't make any difference whatsoever and didn't add very much weight to them, so I wouldn't recommend it. Eventually, I'll replace the sand with lead shot. If you decide to use lead shot, please post your results. Thanks.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
What if you used lead shot and then added sand to fill any gaps created by the lead? I'm not sure what size shot you guys are talking about using so it might not make enough of a difference to be worth the hassel.
I would think pennies might rattle a little, whereas lead and sand seem to be quite absorbant and dead. -
#5 shot is very small, not much in the way of gaps to fill, but nothing says you can't do both.Political Correctness'.........defined
#5 or #6 lead shot, $16.99 a bag at Gander Mountain. I fill only about a third of the column. It seemed to me that when I filled the entire column that the weight was too high and made them top heavy. Filling only the bottom third seemed to anchor them better and the weight was bottom heavy like it should be. With a third of the columns filled, they are heavy enough it seemed.DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
That's where I get my shot, Gander Mtn.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
allright, will go with lead. I might roll with lead on the botton, sand on the top. I thought of the low center of gravity issue dkg brought up.
I was worried the lead would rattle if not mixed thooroughly with sand. seems that is not the case. that was my biggest worry. thanx for the help guysLiving Room 2 Channel -
Studio Rig - Scarlett 18i20(Gen3) DAW, Mac Mini, Aiyma A07 Max (BridgedX2), Totem Mites -
F1nut wrote:Use heavy latex gloves when handling.
Huh? Do you put on an iron lung before you eat a pack of Winston?Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service. -
my apollo oz6's are just filled with sand. they have quite a large central (slightly thinner than a drain pipe.)tube that's heavy enought with sand in it. lead would proberly be better.
http://www.apollohifi.co.uk/speakersupport.htmELECTRONICS
arcam cd93
linn wakonda
MC2 MC450
Teac ud h01 DAC
SPEAKERS
Tannoy DC6 t se .
