Where do I go next?
TonyR
TonyR Posts: 9
edited February 2006 in Speakers
Hello all,
I would appreciate some advice on which Polk speakers would best complete my HT system.I have a Yamaha HTR5890 7.1 channel receiver,RTI 10 towers,
CSI 3,RTI 4 surrounds and psw10 sub.What should I add for presence speakers and back speakers.Your thoughts would be helpful.
Yamaha rx z9
Rti 10's front
A6 center
(2) Psw 505 subs
Rti 10's sides
Rti 6's backs
Post edited by TonyR on
  • kmartin971
    kmartin971 Posts: 236
    Add RTi 10s or 12s, use the RTI 4s for rear, move the RTi 10s to sides and forget about the presence speakers. You can not run them at the same time as the rears anyway. Add upgrade the center to a CSi5.
    TV = WS65611
    Pre-Amp Onkyo 830
    Amp Aragon 2007
    Panamax 5510
    Towers = LSi25s
    Center = LSiC
    Side Rear (2) = LSiFX
    Rear (2) = LSiFX
    JBL S120P II
    Sony Upconverting DVD Player
    XBox
    XBox 360 (Wireless connection live and media center enabled)
    PS3
  • TonyR
    TonyR Posts: 9
    Thanks K great idea.
    Yamaha rx z9
    Rti 10's front
    A6 center
    (2) Psw 505 subs
    Rti 10's sides
    Rti 6's backs
  • chrisrud15
    chrisrud15 Posts: 48
    New sub maybe. I dont have near the quality of speakers you have and im not happy the way the PSW10 performs. I tweaked it every which way and decided that my old Infinity sub sounds better.
    HT- CS1, Infinity 12 in. sub, Onkyo receiver, m20's, and m10's
    Car- Polk MOMO 6500 components, alpine 2 channel amp, Pioneer HU, Infinity Kappa Perfect 10 in. sub, Diamond Audio amp
  • TonyR
    TonyR Posts: 9
    Thanks Chris appreciate your thoughts.
    Yamaha rx z9
    Rti 10's front
    A6 center
    (2) Psw 505 subs
    Rti 10's sides
    Rti 6's backs
  • dkg999
    dkg999 Posts: 5,647
    Replace the CSi3 with a CSi5, sell the CSi3 and get FXi3's for the side surrounds, move the RTi4's to the rear surrounds. Replace the PSW10 with something like an SVS PB10. JMHO!
    DKG999
