4 Side Surrounds?
soiset
I am using S4's (direct radiating) as my side surrounds in my 7.1 system, and am thinking of adding another pair, instead of going dipole. The S4's present an 8 ohm load. I was thinking I'd wire the side surrounds in parallel to get a 4 ohm load, and have my Yamaha RX-V2500 adjust the sound level again. The receiver is switchable for 6/8 ohm loads, and the specifications rate dynamic power against 8/6/4/2 ohm loads. RMS power is rated only at 8 ohms.
Has anyone tried this arrangement? Any warnings or advice?
Post edited by soiset on
where are you placing them? I cant see them making that much of a difference. do you notice a weakness in the surrounds on your set up, hence what provoked this move? what lead to the decision?Living Room 2 Channel -
Schiit SYS Passive Pre. Jolida CD player. Songbird streamer. California Audio Labs Sigma II DAC, DIY 300as1/a1 Ice modules Class D amp. LSi15 with MM842 woofer upgrade, Nordost Blue Heaven and Unity interconnects.
Upstairs 2 Channel Rig -
Prometheus Ref. TVC passive pre, SAE A-205 Amp, Wiim pro streamer and Topping E50 DAC, California Audio Labs DX1 CD player, Von Schweikert VR3.5 speakers.
Studio Rig - Scarlett 18i20(Gen3) DAW, Mac Mini, Aiyma A07 Max (BridgedX2), Totem Mites -
Often the ambient effects "collapse" to a single speaker, and I thought that I could get a more diffuse sound with more speakers, especially if I reversed the phase in them. My surrounds are all at about standing ear level. I was thinking that with two on each side, I could angle them in different directions instead of aiming the singles straight over the back of the couch, which is where they are now.
try it, but wire them in a series, not parralel. your reciever will thank you., it cuts power, but just calibrate accordingly and I can see it being a problem. worse that can happen (with the series wiring) is it sounds horrible and you disconnect it. parralel wiring, with a dip to 4 ohms, could do damage to your reciever despite the ratings.Living Room 2 Channel -
What do you think about wiring them out of phase? I am thinking just to reverse the wires on the drivers in one speaker per side would do the trick. Could it be done with the speaker cables instead?
I have decided to get a two channel amp to run my extra side surrounds. I'm hoping that an older Yamaha amp will sound enough like my RX V2500. I still don't know if I should wire the second pair out of phase, though.
Note to self......................don't buy used receiver from Bellaire TX.;)
If you want dipoles, buy'em and leave the engineering to the experts.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Try it, and see what it sounds like, it won't hurt anything. And yes, wire them in series, usless your amp is 4 ohm capable at whatever the output of both your speakers are. (My guess would be no) If you wire them in series, it will present a load of 16 Ohms to your amp, and you will get a little less power than at 8 Ohms, but it will still sound fine, and you won't overload your amp.
wouldn't running them in parallel via speaker cable lead to a 16ohm load?
Y-Adapters w/ rca interconnects could be different.
