Neo Magnus
VR3
Assuming I get the Image Dynamics ID8 in the flea market (one)
Specs -
* Size: 8 inch
* Rec. Sealed Box Dims: 0.20 - 0.45 cu.ft.
* Rec. Ported Box Dims: 0.50 - 0.70 cu.ft.
* Free Air Usage: yes
* Sensitivity: 85.6 dB
* Frequency Response: 10-150 Hz
* Recommended RMS Power: 50-300W
* Peak Power Handling: 350W
* Impedance: dual 4 ohms subwoofer wiring options
And I make an enclosure (external) 7" (bottom) to 4" (top) (straight back/front slope) - with 3/4" MDF...
How big would the box have to be to get .20 Cu Ft? - And what would the response be?
Im wanting atleast 30-35 hz response... how big would it have to be to get this?
thanks
Specs -
* Size: 8 inch
thanks
Post edited by VR3 on
how tall? or how wide? give one of those dims and the other can be calculated.
how deep is the driver, will it fit in that box?Dodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
hoosier21 wrote:how deep is the driver, will it fit in that box?George Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Pioneer Premier DEH-P860MP, Memphis 16-MCA3004, Boston Acoustic RC520 -
hes giving top and bottom dimensions so neo can go into winisd, enter in all the t/s parameters to where he can get a 30-35Hz frequency. The sides can be longer as long as he gets the right frequency...at least thats what im guessing.
The height need to be about 15 Overall - width is a toss up to what the program says...
The sub is 4.75" deep, from what I read. Should fit as long as I keep it in the lower portion. (I can always add a spacer ring to it)- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
exalted512 wrote:hes giving top and bottom dimensions so neo can go into winisd, enter in all the t/s parameters to where he can get a 30-35Hz frequency. The sides can be longer as long as he gets the right frequency...at least thats what im guessing.
-Cody
but he would still need to know the height of the box to figure the length or know the length to calc the heightDodd - Battery Preamp
Dimensions/Known External
7 (B) - 4" (T) (depth) x 15" (Height) - External
Width is variable
3/4" MDF- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
i'll post a prelim design by the end of mondayIt's not good, very fundamentally simply not good. - geolemon
awesome, thank you!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
okay... you need a box about the width of the sub to make .2 cubic feet... you will NOT get great extension out of that... these numbers take a rough approximation of cabin gain into account...
set 95 Hz = 0 dB
then 85 Hz = -3 dB
72 Hz = -6 dB
63 Hz = -9 dB
40 Hz = -17 dB
30 Hz = -21 dB
make the box 3 feet wide, and you get flat down to 74 Hz, -3 dB @ 49 Hz, -6 dB @ 38 Hz, -9 dB @ 30 Hz, and -15 dB @ 20 Hz, a much more respectable set of numbers
phase is actually more uniform with the smaller one, the bigger one could have the 'late-bass' phenomenon, but it's not so whacked-out that that should be an issue... ditto for group delay...
i'm seeing a max SPL of 111 dB @ 100 Hz, 98 dB @ 55 Hz, 80 dB @ 20 Hz for the small box, whilst the large box has 111 dB @ 100 Hz, 108 dB @ 55 Hz, 91 dB @ 20 Hz...
the sizes in between follow a roughly linear pattern, but these are the two extremes you should consider... ported boxes aren't looking so good, you simply don't have the space available to make one work for your needs... i can work through more iterations if you like, but if that's what you were looking for, so sorry...It's not good, very fundamentally simply not good. - geolemon
So a box...
Externally - 15" tall, 7-4" deep with an angled front, 36" wide
So itll be... 13.5" Tall, 5.5- 2.5" deeph, 34.5" wide internally?
And itd get -3db at 50hz, 40hz at -6db - thats not TOO bad...
What if we could bump the height another 3" - how much could the width be cut down to get similiar volume?
Thanks for your help!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
What if we put 1+ pounds of polyfill in it?- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
so... much... tiredness... i'll look at this again when i'm more awake, later today...It's not good, very fundamentally simply not good. - geolemon
Bump
Just seeing where this may go, Id like to get started on a box shortly...
Thanks!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
ah! so much sorriness! totally forgot... i am... ah... not going to be here for the rest of the evening, so perhaps once i awake tomorrow i can finish the design...It's not good, very fundamentally simply not good. - geolemon
hey... sorry for the delay on the box, but i'm gonna have to back out on this one... i hate to go back on my word like this, but i've got way too much **** on my plate at school right now...
sorry... i hope the data i was able to provide was able to help at least a little bit...It's not good, very fundamentally simply not good. - geolemon
Its cool man...
Thanks anyways.
Anyone else able to design a box for me?- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
