amp and cd player flash on and off?
low95ryda
wuz up guys? i think my battery is about shot because its 6 years old,but i would your really like your guys advice. I have a Directed D2400 3 12 in Polk Momo subs and a pioneer cd player, its been instaled for about a week now sounds awsome but after a while the cd player turns on and off and the amp does it too but it goes into protect i was going to go have it hooked up to the mic but i would like to have this problem fixed first
Post edited by low95ryda on
if it takes a while for the protection to begin kicking in, and then it goes on and off at intervals, i'd say that's the temperature protection circuit... ensure that you have adequate airflow over the amp, and that it's not mounted upside-down or anything crazy like that...
second guess would be the standard 'check your connections, especially grounds'...
try turning it on and playing at very low volumes for a while... does it kick into protection then? does it kick in faster if you play it really loud?It's not good, very fundamentally simply not good. - geolemon
sounds like a current supply problem . check your other post.88 Wrangler 383 stroker 525hp 10 inch's of lift 38.5's
Premier 860mp 140 & 200 amp altenator
MMC6500 driven vy c300.2
MMC690 driven by c300.2
2-MM2104's driven by c500.1 -
Its your battery. Get a new one with as high a CCA rating as you can get. Dont forget to get one with a stout RC as well.polkaudio sound quality competitor since 2005
