Should I upgrade my Denon 1905 receiver?
Canedog
Canedog Posts: 22
edited February 2006 in Electronics
Just got back from Tweeter and the 'cheapest' AMP they had was over a grand... I have around $500 to spend.
I have RTi10s fronts, CSi5 center, FXi5 rear and a Velodyne/Polk PSW 10 sub combo. I'm using a Denon 1905 receiver and I am not impressed with the sound. Movies sound okay, music sounds bad.
Tweeter has an 'open box' Denon 3805 of $688. Should I sell my old Denon 1905 and upgrade to the 3805? Would I see much of an improvement in sound quality?
At this point, buying an AMP may not be an option for me.
Post edited by Canedog on
  • dragon1952
    dragon1952 Posts: 4,917
    For $500 you could get a kick-**** used amp on Audiogon or even Ebay. That's the route you should take. I don't think you'd notice as much benefit by going to the 3805. However, Tweeter should have a return policy. You could always take it home and give it a test drive. You just missed out on Russman's Conrad Johnson Sonographe for around $350 shipped. That would have worked great.
  • Ferres
    Ferres Posts: 310
    There is a review of the 3805 here:
    http://www.hometheaterhifi.com/volume_11_2/denon-avr-3805-receiver-6-2004.html
    It seems to be a better option over all. Detachable powercord too which is always a plus for me. :)
    It can be a starting point of a bigger system with addition power-amps to be added later, assuming this is in the cards. :o
    Gear: Rotel RC 1082, Rotel RSP 1068 pre/pro, Rotel RMB1077 amp, Cayin CDT 15a CD player, S301 bluray.
    Speakers: Tannoy DC sensys speakers, Paradigm Servo15 Sub, Velo Spl-1500r
    Conditioner: Isotek :D
  • mldennison
    mldennison Posts: 307
    i doubt that you are going to get all that much improvement from switching to the 3805.
    i also think you can do much better than $1000 for a quality amplifier. if you dont like the idea of a used item, go with outlaw...they have thier one-channel amplifiers for like $200 each, 2 of those will still keep you under $500 and would be much better than the 3805 IMHO.
  • *Seby*-Polk-
    *Seby*-Polk- Posts: 375
    If you don't like Denon sound...don't like the 3805 :(
    Try another brand, like Harman Kardon, Yamaha RX-V2500 or Marantz. in this receivers you hear another sound, more bright in Yamaha, more bassy in marantz ... try it !!!!
    My current new system (step by step :D)
    A/V Receiver: YAMAHA RX-V657
    DVD Player: YAMAHA DVD-S657
    Main Towers: polkaudio® Monitor 50
    Wiring: NeoTecH KS1007 OFC High Definition Speaker Cable ( 2 x 2.64 mm² )
  • *Seby*-Polk-
    ohh sorry ... for Watch movies...for me, Yamaha is the winner. Music, maybe HK :)
  • Ferres
    Ferres Posts: 310
    Lol! I'm still using my Marantz sr6300 and I'm pretty happy how it's keeping up with the occassional upgrades. :)
  • *Seby*-Polk-
    Yeah...your receiver is great ;)
  • Toxis
    Toxis Posts: 5,116
    I'd definitely say the 3805 would be a great start for you! It'll dominate the 1905 in sound quality. I say get it (but offer $600 just to see if they'll take it)! Then later if you want more, then you'll have a better processor to build off of. Or see if there's a return policy and give it a try. If it's not a huge upgrade in your home, then consider finding a good amp.
    There's a lot of amps out there you can find with good power for around $500. I know the marantz mm-9000 is a great amp and can be found for that range. Adcom and older Rotels are also great for the money. You also might want to save a few extra bucks and see if there's something significantly better for a little more. I found an amp that usually sells for $2500 with about 100 hours of use on it and got it for $780 shipped thanks to the bay. Deals are out there... maybe even on a 3805!
  • MrNightly
    MrNightly Posts: 3,370
    I'm walking proof that deals are there too.. Picked up the 3805 for $600 plus shipping. Hell of a deal. In my limited HT experience, this is a great start to power those big boys... I went with the RTi8's up front, and man, I think they sound awesome with the 3805. I understand the 10's are bigger and require more power, but I concur that they would be a solid stepping stone for you!
    What can it hurt? Give it a shot. If you don't like the 3805, sell it on here for what you paid, and you're no worse off eh?
    Honoured to be, an original SOPA founding member
    Stuff...
    RTi12's - front
    CSi5 - center
    FXi3's - surrounds
    RTi4's - surrounds
    SVS PB12-NSD/2 - sub :D:D:D
    Denon 3805
    Rotel RB-985 5-Channel Amplifier
