Info on CS 350LS required....
bmacker
Have searched Polk site and cannot find the specifications...I am looking at upgrading from a CS 250-S to the 350LS and I think they are a 4 driver + tweeter arrangment but I am struggling to locate pictures, dimensions and general information - anywhere...
The forums have some discussion on these and it seems it will be a worthwhile upgrade and it is being sold with a pair of LS50's, which seem like they would be a step up from my RT8's.
Any help appreciated....
Post edited by bmacker on
Send me a PM if nobody else replies back on this. I have one at home that I use. And will send you the dimensions, specs etc. (if I can locate the manual)..
Yes - 4 drivers, and one tweet.... -
http://www.aracnet.com/~nwolff/theater/cs350.html
Here you go..........
Driver Complement
Mid/woofer
4 each 4 1/2" (11.4cm) Dynamic Balance® mid-woofers
Tweeter
1 each 1" (2.5cm) Dynamic Balance® Tri-laminate dome tweeter
Cabinet Dimensions
6 1/2"H x 26"W x 11"D
16.5cm H x 66cm W x 27.9cm D
Overall Frequency Response
40Hz - 26kHz
-3db Frequency Response Limits
60Hz - 25kHz
Recommended Amplifier Power
10 - 250 watts/channel
Efficiency
91dB
Nominal Impedance
compatible with 8 ohm outputs -
Thanks so much for the quick reply - Much appreciated.
Should go well with the 50's...More later,
Tour...
Vox Copuli
