rm6751 Sat Question
nipperjc
nipperjc Posts: 2
Hi all,
I have the rm6700 sub/sat package, which uses the rm2350 sats as the front and rear speakers. When I upgraded my receiver I was able to transition to 7.1 audio. Right now I'm just using 2 old bookshelf speakers as the surrounds, but I'd like to get matching Polk's since the current ones sound like crap. The rm2350 sats are no longer sold, and I haven't had a lot of luck on eBay or other net sites.
Can anyone tell me how the rm6751 sats will blend with this system? I see they have a slightly larger midgranger driver but a smaller tweeter. They also, unfortunately, use spring clips. However, Crutchfield has them at ~$60/each, which seems reasonable.
Thanks for any help!
EDIT: I posted this in the wrong forum, can a mod move this tread to the "Speakers" section?
