Bridging amps???
unc2701
unc2701 Posts: 3,587
edited February 2006 in Electronics
Ok, check out the attachment... Can you do this with any amp??? (assuming that you can get the reversed phase on one channel)
edit: sonofawhore attachments aren't working. Basically, you use a y cable to feed a single signal to both channels, put one channel 180 degrees out of phase, wire the negative terminals together and wire the speaker to the positive terminals.
Backburner:Krell KAV-300i
Post edited by unc2701 on
  • thehaens@cox.net
    thehaens@cox.net Posts: 1,012
    No attachment...................
  • unc2701
  • thehaens@cox.net
    I still couldn't get the pdf to open, must be the lunch hour traffic...
    anywho, I don't think this would work with any amp, but I am still a bit fuzzy on the logic of what the phase has to do with it.
    I know that Sunfire has an odd way to bridge as well, they combine a Lab output w/ the L/R on the single channel, then cross splice something else, then roll into another output etc. It was far to confusing when I read it in the manual, and I was only using it for stereo anyway so I didn't pay to much attention.
    Back to your question.
    On my parasound it is pretty easy to bridge. From the Pre/Amp Left Out to the L input on one of the amps. Then run a single speaker wire across both speaker terminals(it is labeled)
    From the Pre/Amp Right Out to the L input on the other amp, and run the speaker cable the same.
    scott
  • unc2701
    Flipping the phase makes the positive terminal have the proper potential across them.
    Lets say +1 volt on the input gives you +30 volts across on the red vs black terminals. So if you flip the phase on one channel, then you get +30 across the one side, -30 across the other side, so the net is +60 across the positive terminals. I'm just surprised because these are basically monoblocks- they share a chassis ground, but that's it, but it seems to imply that you can bridge-mono just about any amp just by flipping the phase on one input (if it's a common ground amp).
    heiney9 Posts: 25,440
    Can't get the .pdf to load either.
  • unc2701
    Ok, I'll try attaching it from home tonight.
  • jmierzur
    jmierzur Posts: 489
    My amp has the ability to run bridged in this manor. Instead of having a polarity switch, it has two RCA inputs out of phase for each channel.
    Simaudio Moon W-3 manual
    Refer to page 10.
  • unc2701
    Huh... it would certainly seem that one could easily rig a bridge mono switch onto any amp with an XLR input or a phase switch. I need to find an old amp and a crap driver to try this out on...
