Can someone help me
karpiel666
Can someone please help me on THIS thread.
dvd player: samsung DVD-HD850
receiver: Denon avr5700
center: polk cs400
fronts: polk rt800i
surrounds: Unknown Polk monitor? series.
sub: svs pb12 isd/v
tv: 46 inch samsung
center: polk cs400
fronts: polk rt800i
sub: svs pb12 isd/v
tv: 46 inch samsung
Thats the problem. I dont have the ratshack one. I know that it has correction values, and Im wondering if my different one would have different correction values.dvd player: samsung DVD-HD850
center: polk cs400
fronts: polk rt800i
sub: svs pb12 isd/v
tv: 46 inch samsung -
karpiel666 wrote:Thats the problem. I dont have the ratshack one. I know that it has correction values, and Im wondering if my different one would have different correction values.
try a google search and see if you can find any correction values. I would assume it needs some, but would not just use the RS values.Dodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
No luck
, guess im gonna have to test it against one they use at frys. dvd player: samsung DVD-HD850
center: polk cs400
fronts: polk rt800i
sub: svs pb12 isd/v
check your instruction manual on the meter.. the only setting you should need to use is weighting, and slow speed..PolkFest 2012, who's going>?
