DIY projector
doggie750
I did my homework here but It seems that no one in this forum have tried to built one? If someone did please 2cents is appreciated. This is a project that I would like to explore. Research from other AV forums have been conducted. Need a POLK brother who had challenge himself to this.
Much loVE
Much loVE
Godspeed,
D0661E
AVR:Pioneer Elite SC-07
Surrounds: RTis
2channel:Rti100 (carver driven
Sub:SVS PB12-Plus/2
Dedicated AMPs:Adcom GFA535, 2xCarver 1.5t, Carver m1.0t
Wsrn:Hitachi ultra vision LCD60, 32XBR400
PowerConditioner: MonsterC HTS5100
PS3, Toshiba HD A2, etc: SonySACD/ Panasonic gears DIVX.
MR3LIGION: Polkaudio; GSXR; E46; Reeftank;
Odyclub; Xsimulator; Sony; Zune; Canon
D0661E
Surrounds: RTis
Sub:SVS PB12-Plus/2
Post edited by doggie750 on
I had planned on building one but sort of strayed away from it since I'd have to order the majority of my stuff from accross the border.
Check out diyaudio.com - they have tons of info on building their own. I read for hours and hours there about them and what you can accomplish with a couple hundred bucks and a good weekend.
If you want to try something cheap to start out you could research the 3" lcd controller projector. It uses a slide projector and a $20 playstation controller to produce an image good up until about 45". I bought a controller but never found a suitable slide projector for the task. -
I was going to mess with this, bought an LCD panel, then never got around to it. Proxima Ovation... I believe it's 800x600, S-video, RGB, composite. It's been going for around $50-$60 on ebay. $40 shipped, assuming you're not in HI, AK or Canada...
PM me if you're interested, and I'll check it out tonight & make sure everything is still working,etc.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
There just so much information on how to build one and so many support sites and I am just afraid picking up the right one.
Several links are attached:
http://www.denguru.com/2004/11/13/supersize_your_tv_for_/index.html
http://www.diyaudio.com/forums/showthread.php?threadid=281
http://forums.bit-tech.net/showthread.php?t=68049&highlight=diy+projector
http://www.lumenlab.com/
:rolleyes:Godspeed,
D0661E
Surrounds: RTis
Sub:SVS PB12-Plus/2
Odyclub; Xsimulator; Sony; Zune; Canon -
Dude, you're making it too hard. Pick up an LCD- Use an overhead panel like the one I have, hack apart an old lcd monitor, or find a smaller panel and take off the backlight. Get an overhead projector; choose the projector based on how big you want to go (bigger size needs more lumens). Put the LCD on the projector, turn it on.
Everything else is just cleaning things up so they look nice.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
add a fan to uncs post & thats what I did buy a cheap lcd from fleabay got mine for $12 local pickup had been droped lcd was find plastic on the other hand was a diff story. I make fiberglass sheets so I use that to space the projector to the lcd filled in the gaps & added 3 chipset fans to it.
#1 heat kills lcds so cool it & space it or kiss it good bye.
#2 more watts on the light is a better pic. MORE HEAT
#3 trying to make a old school projector look good. We are going to build a house next year & as it looks pretty good im going to build it in the back wall.
Its well worth the time & money you put in it. But don't expect it to look like the movies. Good but not great..!..!..
Note I have also seen older 640X??? ready made projectors with lcd most say for laptop use but they go around 50 ish.
I WAS HERE -
....or buy a barely used LCD projector cheap on ebay that's got a small footprint, looks nice and saves you the hassle.____________________________________________________________
