ring and spade terminals?
diego_sapphire
diego_sapphire Posts: 11
edited February 2006 in Car Audio & Electronics
I see these in amp install kits. What are they used for?
Post edited by diego_sapphire on
  • neomagus00
    neomagus00 Posts: 3,899
    attaching speaker wire to speakers or power wire to batteries
  • exalted512
    exalted512 Posts: 10,734
    or speaker wire, power, ground, and remote wires to amps
    -Cody
  • diego_sapphire
    -Cody
    so how many sets should i get if i have two amps that i'll be installing, one for dual subs and another for front component speakers? i believe the front speaker wires will be running to a passive x-over, not the actual tweeter/woofers themselves.
  • exalted512
    ive never used them for my amps, just for speaker connections. Looks a little cleaner, but I couldnt really care less.
    Buy more than youll think youll need, theyre not very expensive
    -Cody
  • neomagus00
    i'm with cody, i never use the terminals, i find them annoying... if you want to use them, get em for the speakers/subs... bare wire for the amps (if they'd even take terminals)...
  • exalted512
    all amps take spade terminals, its looks a little "cleaner", possibly a little safer since you wont have to worry about little strands of wire crossing over and touching something else, but i dont use em. Probably will for my next install, but only because it might help me get some extra points in competition
    -Cody
