New Lsi9s and "Blu-Tack"?
resperc
resperc Posts: 41
edited February 2006 in Speakers
I just got my new speakers (Lsi9, LsiC, and Lsi7). They sound awesome. These speakers will be replacing RT55s, CS400, and FX500s. I am so excited. I also bought a pair of Target Audio HR70 stands for the Lsi9s. I will be filling the stands soon with shot and sand. I have heard that some people use/recommend "Blu-tack" (damping compound) to help secure speakers to the top plate on speaker stands and they claim it is very secure and does no permanent damage.
Do any of you do this? Do you recommend it? Will it damage the gloss finish on the bottom of the Lsi9s?
Any suggestions or comments are appreciated. Thanks in advance. Resperc
Post edited by resperc on
  • tryrrthg
    tryrrthg Posts: 1,896
    I use it on my Dynaudio's and my Polk's. It shouldn't damage anything, just be careful when you try removing the speakers from the stand. Don't try to do it quickly, they will be really stuck. Just wiggle the speakers back and forth until it comes loose. I've used it on my speakers for several years with no problems. That stuff has an iron grip on your speakers, it's good piece of mind to keep them from falling off the stands.
    billbillw Posts: 6,850
    I second that. Blu Tack is awsome stuff and it will not do any permanant damage to the finish. Once you unstick it, just rub off any residue with a cloth. I use it all over the place for vibration damping, sticking stuff, and to fill gaps sometimes too.
    For rig details, see my profile. Nothing here anymore...
  • unc2701
    unc2701 Posts: 3,587
    Yep, I use it, too. Keeps the speakers in place even when the g*****mn cat jumps on top of them.
    Backburner:Krell KAV-300i
  • aaharvel
    aaharvel Posts: 4,489
    going to try this Blu-Tac stuff. Thanks and good thread.
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
  • unc2701
    Oh and don't pay $10 for it from audioadvisor- should only cost you $3. Try staples, office depot, art supply stores, etc.
  • aaharvel
    thanks- will make the trek today
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
  • tryrrthg
    Yep, something like this works great.
  • resperc
    resperc Posts: 41
    Thanks for all of the replys. I am going to get some "Blu-tack" this weekend when I get the sand and shot for my new speaker stands. I can't wait to get it all set up. Resperc
  • rnp614
    rnp614 Posts: 598
    So normal poster gunk works for this purpose?! Thats all "blu-tack" is?
  • tryrrthg
    yep, works like a charm.
  • unc2701
    Yeah, I do find that blu-tack seems to hold its stickiness longer, but maybe that's just because I could see how dirty the white, generic stuff was.
  • michael_w
    michael_w Posts: 2,813
    Not a bad idea... I wouldn't try it with speakers that offer an unsealed veneer or something just in case the residue decides to get mashed into the wood grain but with a gloss finish it should be fine. Might have to try this with my 7's if they're ever in a position where I might bump one.
  • resperc
    resperc Posts: 41
    So...
    I will be using "Blu-tack" on my new stands and speakers, but how much? Do you guys cover the whole top plate of the speaker stand or do you just apply it at the corners?
    Thanks for the advice. Resperc
  • tryrrthg
    Just a pea to marble size piece at each corner should more than do the trick.
