LSi15, how close is too close?
Ethos
Ethos Posts: 4
edited February 2006 in Speakers
Hey, I don't post often but appreciate all the good advice on the forums.
I've got a pair of LSi15s in a bedroom setup where the distance from my listening chair to the speakers is limited. How much space do the 15s need for good integration of the different drivers?
Many thanks.
e
Post edited by Ethos on
  • gregure
    gregure Posts: 871
    I've set my speakers up about 16 feet from where I sit to listen, and they sound better than ever. I'd say if you're within 10 feet you're not really doing them justice for music, but theater wouldn't be too bad. Also, the further they are apart can help with the depth of sound.
    Current System:
    CSi5-Center (for sale**)
    FXi3-surrounds (for sale**)
    Martin Logan Depth-Sub
    B&K AVR 507
    Pimare CD21-CD Player
    Denon 1815-DVD Player
    Panamax M5500-EX-Line Conditioner
  • Ethos
    Ethos Posts: 4
    Thanks for the quick reply. 10-16 ft away would be terrific but isn't possible in my situation. I'm wondering if 6-7 ft in a triangle configuration would seriously compromise the sound.
    e
    VR3 Posts: 29,427
    I sit 4-5 feet away, beat that!
    Let me put it like this...
    It is far more important how far they are from the rear and side walls..than they are from you.
    As long as they are 2 feet from the rear and side walls...you will be ok (if you can go more, go more...
    4-6 feet from the rear and side walls would be awesome! :)...
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    Too much speaker for the room, but you should be set when something changes and you have a bigger room to fill.
  • ezc
    ezc Posts: 426
    I sit about 9 ft away from my 15's. I have them away from the back wall, towed in, & tilted back. Im very happy with the sound & have messed with placement for awhile & I think now I finally have them dialed in for 2ch.
  • scottyf
    scottyf Posts: 129
    I am roughly 8 ft from the speakers. They are 3 feet from the back wall, 2 feet from the side wall and about 6 feet apart. I am also 3 feet from my back wall.
    This works for me and negates a really bad base node I suffer from if I am on any of the walls.
    HOME: VPI Classic/Grado Reference Master, EVS-modified Oppo BP83, Bryston DAC, Counterpoint 3000/SA-100 modified by Alta Vista, Polk LSi15
    TRUCK: Pioneer 8600MP, Soundstream 300SX, pr of Xtant 1001i, Autotek SS490.2, Polk SR6500, Polk MMC6500, pr of Polk MM2084DVC
  • gregure
    gregure Posts: 871
    While there's no right or wrong answer, sitting further back does allow the sound to spread out more, adding depth and imaging. Optimally, the speakers should be at least 10 feet away from each other, and one should sit at least 10-15 from the central point between them. This is, of course, optimal, and most of us can't quite achieve this in our homes, unless we have a dedicated room, or an understanding wife. This is all for two-channel concerns, of course.
    Current System:
    B&K AVR 507
  • Ethos
    Ethos Posts: 4
    Many thanks to everyone for the advice. I spent a couple days experimenting with the placement based on the suggestions and thought I'd share what I found.
    The placement relative to the sidewalls was the biggest consideration in my set up. Too close and the bass became muddy/boomy. the distance between the speakers didn't matter as much in terms of imaging, though. I have some toe-in but not as much as I did when they were in a bigger space. I think the imaging may have suffered a bit as a result but too much toe-in really affected the overall tone--it made the highs seem a bit bright (which wasn't an issue at all when the speakers were further away from my listening chair). Overall, I'd say the set-up was a lot fussier with the distances reduced.
    Hope this helps others.
    e
