Surround Speaker Selection and Placement
Pizza-King
Pizza-King Posts: 2
edited February 2006 in Speakers
Hey All... I'm getting ready to purchase speakers for my home theatre system and wanted to get some input on my rear surround speaker selection and placement. To start with, I plan on getting Monitor 30's for the fronts, a CS1 for the center channel and a PSW10 for the sub. Now for the surrounds, because of the layout of the room (see attached) I'm in a little bit undecided on what to get. The main listening area is about up against the back wall with the door to the room to the left of the sofa. So putting speakers on stands to the sides of the listening area is pretty much out of the question. I thought about getting monitor 30's for the rears and mounting them on the wall, but I'm leaning away from that idea because of the "eye sore" that would produce. In-wall speakers to the sides is also out because of the way the studs are around the door so the in-walls would end up being too far towards the front. So now I am leaning towards in-walls in the rear wall firing forward towards the tv. What is everyone's thoughts on the best surrounds to match the rest of the system and how to mount them? Will the in-walls firing forwards sound ok?
Thanks for your input.....
Jeff
Post edited by Pizza-King on
  • StopherJJ1980
    StopherJJ1980 Posts: 267
    In walla sounds great, Hope it works out well for you :)
    -Stopher
    Tempe, AZ
    Setup:
    Polk RTi8 Mains
    Polk CSi5 Center
    Polk FXi3's Surround
    Cerwin Vega HTS10 Subwoofer
    Yamaha HTR-5740 AVR
    Upstairs R50/R15/CS1 5.1 setup w Pioneer AVR
  • reimersnj
    reimersnj Posts: 2
    i wouldn't do the in-walls simply because it's a lot of work for a system that is low end. it will sound good but if you're gonna go through the effort of doing minor construction i would get higher end speakers all around. i would go for the wall mounted surrounds. if done right they won't be too bad.
  • wingnut4772
    wingnut4772 Posts: 7,519
    I kind of agree with reimersnj. This hobby has a HUGE learning curve and you may find out 6 months from now that where you put those big holes in the wall is not the ideal spot for your surrounds, or you want to get a different model etc. Unless you know for absolute certain that you are going to stick with those speakers wherever you end up putting them.
    That having been said.....I would remove the side couch entirely and pull up the couch from the rear wall centered on the HT center. (You might want to put the other sofa behind the first on a riser later). I have my surrounds wall mounted and they don't bother me at all (check my signature link) and I am a girl! :p
    What ever you do, I would not put the surrounds anywhere forward of your sweet spot- even if you aim the tweeters I think you would really lack a proper soundfield as it was meant to be heard.
    Good Luck!
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • aaharvel
    aaharvel Posts: 4,489
    welcome to the forums pizza king. Your best bet given your "weird" room would be the fxi surround speakers. However the Monitor 30's and cs1 do not timbre match these.
    Save your money and buy some RTi4's and a csi3. Much nicer speakers, and if you look hard enough- either here on the flea market thread or on ebay- you'll get twice the speaker for a fraction more.
    Yes, the fxi's are more expensive, but they can be had for around $200-$250 per pair if you're patient. They're Less expensive and better sounding/more flexible than in-walls... AND if you have a less-than satisfactory room, as I do.. accept no substitute.
    Welcome to the forum.
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
  • *Seby*-Polk-
    *Seby*-Polk- Posts: 375
    Mmm.. Monitor 30 for fronts....OK. Then get 2 pairs of monitor 30...One for fronts and one for surrounds....Your sistem will be very well balanced. Try it ;)
    My current new system (step by step :D)
    A/V Receiver: YAMAHA RX-V657
    DVD Player: YAMAHA DVD-S657
    Main Towers: polkaudio® Monitor 50
    Wiring: NeoTecH KS1007 OFC High Definition Speaker Cable ( 2 x 2.64 mm² )
  • crazy
    crazy Posts: 443
    Is timbre matching that important?
    Distant Dream - A New Beginning
    www.distantdream.com
    (Now also available on iTunes)
  • aaharvel
    if you want a seamless soundfield YES.
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
  • crazy
    crazy Posts: 443
    So if I want to graduate and replace the Monitor 50's with Rti's 8, it's not advisable? In other words, would I be better off with the 50's till I have enough $$$$ to replace the entire set?
  • aaharvel
    i thought you were going to get monitor 30's for the fronts, not the 50's. Since Your first post suggests that want small bookshelf speakers for the fronts yet you haven't bought anything yet, I suggest getting the rti4 instead of the 30, the csi3 instead of the cs1, and those 3 will match a pair of fxi surrounds- probably your best option placement wise.
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
  • da5176
    da5176 Posts: 42
    IMO, I'd think about Monitor 40s for the fronts and a CS2 for center with Monitor 30s for surrounds. Forget about the PSW10, you can do much better for a sub. Check out Ebay for good prices on these speakers.
    NOT MUCH, BUT IT'S ALL MINE!
    SONY 60" SXRD (HDTV)
    Explorer 8300HD (HD-DVR CABLE BOX)
    Toshiba SD-3750 (DVD PLAYER)
    Onkyo TX-SR702 (RECEIVER)
    Polk Monitor 60 (FRONTS)
    Polk CS2 (CENTER)
    Polk Monitor 30 (SIDE SURROUNDS)
    Polk Monitor 30 (REAR SURROUNDS)
    Mirage Omni S-12 (SUBWOOFER)
    Tripplite HT 1000UPS (POWER PROTECTION)
    Omnimount (CENTER CHANNEL SHELF)
    B-Tech BT34 (SURROUND SPEAKER MOUNTS)
  • Holydoc
    Holydoc Posts: 1,048
    I agree with Aarharvel that the FXi series speaker would be a much better choice for your surrounds. And let me state that I am a big proponent of timbre matching.
    However in your situation and because the FXi series can be set in bipolar mode thus diffusing the sound field quite a bit, I do not think you will have much of a problem with timbre matching with these speakers. Because of the diffused sound the "smoothness" of transitioning from your front stage to the sides and rear is much less noticable. I believe you will be quite satisfied with your FXi's.
    Now if you have not bought anything yet, then do exactly like Aarharvel states and get all matching timbre speakers. Plus I think you will enjoy the RTi series more than your monitors.
    Good Luck and Watch out for this hobby. It will bite you in the wallet!
    Holydoc (Home Theatre Lover)
    __________________________________________
    Panasonic -50PX600U 50" Plasma
    Onkyo -TX-NR901 Receiver
    Oppo -Oppo 980HD Universal DVD Player
    Outlaw -770 (7x200watt) Amplifier
    PolkAudio - RTi12 (Left and Right)
    PolkAudio - CSi5 (Center)
    PolkAudio - FXi3 (Back and Surround)
    SVS - PB-12/Plus (Subwoofer)
    Bluejean Cables - Interconnects
    Logitech Harmony 880 - Remote
  • kmartin971
    kmartin971 Posts: 236
    Yessssssssssss Timbre Match~~!!!!!!!
    TV = WS65611
    Pre-Amp Onkyo 830
    Amp Aragon 2007
    Panamax 5510
    Towers = LSi25s
    Center = LSiC
    Side Rear (2) = LSiFX
    Rear (2) = LSiFX
    JBL S120P II
    Sony Upconverting DVD Player
    XBox
    XBox 360 (Wireless connection live and media center enabled)
    PS3
  • Pizza-King
    Pizza-King Posts: 2
    Thanks to everyone who took the time to voice their opinion.... I'll definetly check out going a different route with the speakers if the wallet will allow...
    Thanks....
    Jeff
