Im getting worried here
karpiel666
I recently moved my svs to a different spot in the room, and finally got around to calibrating it. While I was calibrating I noticed a 10-15db fluctuation in the reading with it set on slow/c weighting. I can hear the variation and if I put my hand lightly on the woofer I can feel it moving more. I have tried setting the sub output to -10 and it makes no difference. Nothing I do seems to make any difference. Could it be the cable? Im using a 10 foot thin **** cheap non subwoofer rca.
dvd player: samsung DVD-HD850
receiver: Denon avr5700
center: polk cs400
fronts: polk rt800i
surrounds: Unknown Polk monitor? series.
sub: svs pb12 isd/v
tv: 46 inch samsung
center: polk cs400
fronts: polk rt800i
sub: svs pb12 isd/v
tv: 46 inch samsung
Post edited by karpiel666 on
Buy a decent subwoofer cable and find out.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
I should re-state that its not so much a variation its more like (bear with me here please) hummmmmmmmm-thud-hummmmmmmm-thud-hummmmmm-thud-hummmmmmm etc.dvd player: samsung DVD-HD850
center: polk cs400
fronts: polk rt800i
sub: svs pb12 isd/v
tv: 46 inch samsung -
WAAA!!! I have no idea! Good luck figuring it out & getting it solved! :eek:karpiel666 wrote:I should re-state that its not so much a variation its more like (bear with me here please) hummmmmmmmm-thud-hummmmmmmm-thud-hummmmmm-thud-hummmmmmm etc.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
okay, not totally sure about the noise you are hearing but the "fluctuataions" in your SPL that you are seeing are normal although somewhat high. where are you pointing your SPL when you are calibrating the sub? since sound at those frequencies are not very directional, i have been told that you should not be pointing directly at the sub but slowly moving it back and forth across the room to get a more broad reading. in this case you will still get fluctuations (i am guessing from the resonance of the room) and you should take the average (give or take) of those measurments as the level. when i do mine, i typically get a 3-4dB range.
Thanks, I will give that a try as soon as my mom wakes up.dvd player: samsung DVD-HD850
center: polk cs400
fronts: polk rt800i
sub: svs pb12 isd/v
and get a descent cable when possible
hmmmmmmmmmmm-thumps can`t be good..!Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool: -
I got the best cable I could, a decent 25 foot, gold plated cable with "Directional sheilding" :eek: I dont know how they do it! It smoothed it out quite a bit, I think most of the variation is from the room now.dvd player: samsung DVD-HD850
center: polk cs400
fronts: polk rt800i
sub: svs pb12 isd/v
tv: 46 inch samsung
