the syetm im thinking bout getting
98thumpin
98thumpin Posts: 649
edited February 2006 in Car Audio & Electronics
after some helpful thought from you alll i ve decided on this system: the mtx shown below, pushing the polk db212-2, polk db-570's in the front and db 690's in the rear, with a panasonic cqc7301u head unit.
what do you think?
John Tyler Birch
home audio system:
Denon avr-1907
Sony dvd/cd changer 5 disc
nakamichi BX-100 tape deck
2 Polk Audio monitor 70's
Velodyne DPS-12 subwoofer
RCA TV
NAK 600 tape deck
Monster power line conditioning power center
Post edited by 98thumpin on
  • brettw22
    brettw22 Posts: 7,623
    Someone proposed using the same amp for your speakers to also power your sub?
    Personally, I'd do a seperate amp for the subs because those will have a much bigger power draw than your other speakers in the car......
  • 98thumpin
    actually i was just going to use the amp to push the db212-2's im leaving the speakers unamped for now i might add a polk amp later if i want.
    John Tyler Birch
    home audio system:
    Denon avr-1907
    RCA TV
    NAK 600 tape deck
  • 98thumpin
    am i going to have to worry about blowing the 6x9's out of the rear deck cause of sub pressure do i need baffles to protect them you know the foam ones or will dynamat wor to protect the speakers, ive also heard putting a little dynamat behind the speakers helps to protect them also
    John Tyler Birch
    home audio system:
    Denon avr-1907
    RCA TV
    NAK 600 tape deck
  • hellohello
    hellohello Posts: 428
    If the pressure is great enough to destroy a set of 6x9;s then i doubt a piece of foam or plastic will help... maybe you could mount one of those wooden 6x9 boxes underneath, that would be my guess, or better yet, dont put the speakers in there in the first place...
    Picking ones nose signifies a strong sense of self discovery :)
    System in the works: ;)
    PP 6V6 with 12ax7 pre ~ 20 watts
    15" Jensen MOD 8ohm ~ 97db SPL
    DiMarzio HS3 and/or Tone Zone S
  • 98thumpin
    i dont think ill be pushing them that hard so i probably dont need to worry about it
    John Tyler Birch
    home audio system:
    Denon avr-1907
    RCA TV
    NAK 600 tape deck
  • 98thumpin
    will circuit city do sound dampening
    John Tyler Birch
    home audio system:
    Denon avr-1907
    RCA TV
    NAK 600 tape deck
  • beardog03
    beardog03 Posts: 5,550
    they sell speaker baffles at crutchfield, but I really don`t think you`ll be pushing enough air to worry about it...
    The baffles may make the 6x9`s sound better, but I`m not sure..
    Dynamat is fairly easy to install if you have the time and patience to do it, or CC may do it for you...not sure....not sure if they even sell it there..
    That`s a question for Cody...
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • beardog03
    That is a great sub setup though..one of the best sounding units sold that`s already put together..
    Very impressive sounding sub/box combo, at a great price also
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • 98thumpin
    oh ok cool i guess it cant be that hard to install huh. so thats cool. i have a cd changer mounted in the trunk will i have to worry about the bass making it skip or tearing the changer all to hell should i have it relocated some where or maybe wrap it in dynamat to protect it . has ne one had this issue before and where else would you mount a changer?
    John Tyler Birch
    home audio system:
    Denon avr-1907
    RCA TV
    NAK 600 tape deck
  • PoweredByDodge
    PoweredByDodge Posts: 4,185
    two polk DX 10's (old 300 watt subs) were enough to blow stock speakers out of the rear deck...
    I solved it by getting some hard plastic speaker baffles (pep boys had them) -- the foam ones aren't as good for the application -- try to get the hard plastic ones.... they're like 5 bucks... you just drop them in under the speaker when you put the speaker in the deck. you WILL be glad you did it.
    as far as the amp... 600 watts is fine for the DB 12's... so ya its ok.
    if you're going to get an amp for your highs, just get a matching 4 channel from MTX....
    The Artist formerly known as PoweredByDodge
  • 98thumpin
    ok cool i was thinking about an amp down the road and if the baffels are 5 bucks or so ill get em it cant hurt i having cc do the install so should i get them and tell them i want them installed at the same time?
    John Tyler Birch
    home audio system:
    Denon avr-1907
    RCA TV
    NAK 600 tape deck
  • 98thumpin
    do i need to worry about the bass from the subwoofer tearing up my cd changer in the trunk or making it skip if so how do i correct the problem?
    John Tyler Birch
    home audio system:
    Denon avr-1907
    RCA TV
    NAK 600 tape deck
  • neomagus00
    neomagus00 Posts: 3,899
    hmm... lets condense this into just your other thread, yah?
  • PoweredByDodge
    the cd changer should be fine - the only thing you have to worry about is the bass shaking it and making it skip.
    however, if it is mounted securely, and it is a decent quality changer (a name brand like kenwood, pioneer, alpine, etc... and not flea market stuff like Pyramid of Legacy) then even hard bass won't make it skip. My 10 disc kenwood rarely if ever skips and its mounted about 3 inches from a box with 4 subs in it.
    As far as the baffles... they should not charge you more to put them in under the speakers as long as they put them in at the same time --- they literally just drop them into the speaker hole and then drop the speaker on top of them (into them).
    it is a good idea to also put some poly fill (it looks like a big giant cotten ball... its the stuff they stuff up cheap pillows with) inside the baffle.
  • 98thumpin
    would baffels be something i could do myself or would it be better to get the baffels and tell them i want them installed when they do the speakers and give them a bag of polyfill.
    John Tyler Birch
    home audio system:
    Denon avr-1907
    RCA TV
    NAK 600 tape deck
  • PoweredByDodge
    to put baffles in, you have to remove the speakers, and then reinstall the speakers... so if you can't put the speakers in yourself, then you can't put the baffles in yourself either.
  • PoweredByDodge
    and they're only gonna need like two handfulls of polyfill... no where near a bag full... hell literally, just two small handfulls. they probably have that much just laying around in the "junk / left over parts bin" at the shop, so i wouldn't go buying a 3 pound bag of the stuff for no reason.
  • 98thumpin
    i could always thro some in my pillow lol. i have a crown vic and i cant see the rear speakers in the deck cause they are coverd over by carpet. i believe they drop in from the top cause from the underneath you cant get to them. im going to have cc, install them from the top and use the grills, that com with the dbs so i can show off the speakers and make them easier to access. does that sound like a good idea.
    John Tyler Birch
    home audio system:
    Denon avr-1907
    RCA TV
    NAK 600 tape deck
  • PoweredByDodge
    sounds fine...
  • 98thumpin
    cool thanks
    John Tyler Birch
    home audio system:
    Denon avr-1907
    RCA TV
    NAK 600 tape deck
  • 98thumpin
    ne ideas on cool trunk lighting
    John Tyler Birch
    home audio system:
    Denon avr-1907
    RCA TV
    NAK 600 tape deck
  • PoweredByDodge
    ehhhh...
    first, LED sticks looks **** in my opinion... so if you go with anything, use regular neon, it has a bit of a warmer glow in my opinion.
    second, i wouldn't go overboard. you are just starting out with one amp and a twin sub box right now. eventually you're going to want to add another amp, or maybe get different subs or just a different box for your subs or whatever... point is, you'll end up moving things around. if you put too much neon in there now, you're not going to have room to move anything or add any gear in the future. and even if you do, you['ll end up having to disconnect and then rewire your lighting. So I'd say two 15" sticks - one on each side of the truck... on opposite sides of the lock mechanism in the middle... up against the tail light section, shooting toward the front of the trunk. tuck them away kinda so you don't see the "guts" of them, just the main bulb and the light they show.
    lighting is one of those things where "more is less" --- a few WELL PLACED lights are way way way way more awesome than a bunch of **** placed lights.
    there's a dude on this board, i forget who he is, but he did just a couple sticks in his car and it looked absolutely sick -- blue light was "casting glow" over his pedals up front and it just accented the car beautifully.
  • PoweredByDodge
    oh - try to coordinate it with your car too...
    i've got a gold (well its more like a funky metallic tan - they call it "metallic almond") truck with a dark navy blue tu-tone on the bottom... so what goes good with gold? purple... i did a streetglow purple neon undercar kit -- 4 three foot sticks (or something like that), and strobe lights behind the grille. came out allright. but had i gone with something like red or green or yellow it would have looked pretty stupid.... the light blue might have looked ok, but i thought it would not go well with the dark blue on the bottom of the truck.
    so keep that in mind when you pick a color... something that goes decent with your ride.
  • 98thumpin
    ok thats a good idea shouls i have it to wear they hit to the bass or just stay light with a soft glow i dont want football field bright. and i have a dark hunter green car.
    John Tyler Birch
    home audio system:
    Denon avr-1907
    RCA TV
    NAK 600 tape deck
  • PoweredByDodge
    ya either way (blinking or solid on) is cool... dark green car, you can do green neon or purple, or even yellow.
  • 98thumpin
    cool
    John Tyler Birch
    home audio system:
    Denon avr-1907
    RCA TV
    NAK 600 tape deck
  • 98thumpin
    yea i think thatll look good.
    John Tyler Birch
    home audio system:
    Denon avr-1907
    RCA TV
    NAK 600 tape deck
  • 98thumpin
    well today is the big day i get my system today i cant wait
    John Tyler Birch
    home audio system:
    Denon avr-1907
    RCA TV
    NAK 600 tape deck
  • 98thumpin
    dont have the system yet but hope real soon. does ne one know if they make any cool trunk organizers for cds and stuff, whats the best thing to use to clean the screen on a head unit and keep it protected.
    John Tyler Birch
    home audio system:
    Denon avr-1907
    RCA TV
    NAK 600 tape deck
  • neomagus00
    trunk organisers? i have a couple 200-CD books, about 12"x12"x3", those work great... for a standard HU, a dry or very lightly damp towel (microfiber preferred) will be fine, stay away from cleaning agents... for a screen, i'd assume the same, but no promises, check the manual...
