CD R/W disc question
madmax
madmax Posts: 12,434
edited February 28 in Clubhouse Archives
I just got a Que 40X12X40 CD burner for my laptop. What is the difference between RW disc's marked 16X or 32X or 40X? Are they better grade and less chance of a miswrite or what? I tried a 40X and a 32X disc so far and both wrote at 40X. Also, I understand some are marked "high speed" and some not. What makes them "high speed"? By the way, USB 2.0 is awesome!
madmax
Vinyl, the final frontier...
Post edited by RyanC_Masimo on
  • dylan
    dylan Posts: 453
    edited May 2002
    They're just able to handle the higher burn speeds. I found this out because I accidentally tried to burn at 16x on a 8x CDR I had, and the music ended up sounding like gibberish, skipping all over the place. I don't think you'll get 'extra' protection by buying a higher speed-capable disc. Usually you can gain better protection by slowing the speed a little, turning off virus protection, defragmenting your hard drives, etc., especially if you get buffer underrun errors. Also, and your mileage may vary, but I've had better luck with TDK or Maxell discs. I've never heard of 'high-speed' before, but 40x is pretty damn high speed, nice burner! :D
    More Info
  • goingganzo
    goingganzo Posts: 2,793
    edited May 2002
    i have a plex 24-10-40 and i have cd r that are certified at 12x but i can burn them at 24 most of the time it is like anything it is a minum speed they have to do but they can go faster just like you can over clock your pc and it is stabble at the higher speed the speed of the prossor was tested and then they bin sort them
  • madmax
    edited May 2002
    That was an excelent article. Thanks!!!
    madmax
