Is there a silk-dome tweeter replacement for the CS-400i?
DollarDave
DollarDave Posts: 2,575
edited February 2006 in Vintage Speakers
Is there a silk-dome tweeter replacement for the CS-400i for a better timbre match to the RTi speakers?
Post edited by DollarDave on
  • shack
    shack Posts: 11,154
    Part # RD6514-3 is a drop-in silk dome replacement for the tri-lam tweeter in the CS400i.
  • hoosier21
    hoosier21 Posts: 4,418
    really, I didn't know they had replacements for that tweeter
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
    VR3 Posts: 29,435
    They dont have a replacement for the Tri-Lam, they send the owners the Silk from the RTixx (Rti70) line...
  • DollarDave
    That's great news! Now, the next obvious question - has anyone tried it and how does it sound?
    billbillw Posts: 7,559
    Haven't tried it, but you should be concerned about matching with the other speakers. If you have tri-lams in all of the other speakers, the silk will not blend as well, but if as you say, you are trying to blend with the newer RTixxx speakers, you SHOULD get a better blend since they are the same tweeter.
  • shack
    shack Posts: 11,154
    I have. Actually there is little difference in sound between the two. For a period of time I had one silk and one trilam in my RT55is. For HT duty any difference was not discerenible. I now I actually have the silks in my front RT55is and the trilam in my CS400i and I can't tell a difference in timbre across the front during movies. I wouldn't know about music as the CS400i is never used for music. If it were me...I probably wouldn't go to the expense of replacing the tweeter in the CS400i since the single tweeter is $70± and I doubt you will be able to tell the difference.
  • shack
    shack Posts: 11,154
    Maybe your best option would be to sell the CS400i and buy a CSi40...like the one in this Flea Market thread:
    http://www.polkaudio.com/forums/showthread.php?t=37391
    You might be able to end up with less cash out than buying a new tweeter.
  • DollarDave
    I think your right. Thanks for the help! I probably won't snare this one, I may just bit the big one and get the CSi-5.
