Listening Makes You Want
janmike
janmike Posts: 6,146
edited April 2024 in Clubhouse Archives
I am sure that a lot of you have experienced going out and listening to great audio gear, then going home and turning your system on only to find that you are missing something. I just went through about 50 songs in the last 2 days and found that I need to upgrade in a bad way. Music sound like S&*T on my average system. I think the trip to Vancouver did me in.
:eek:
Michael ;)
NORTH of 60°
  • janmike
    edited February 2006
    Hey, other people tell me my system is good. I just listened to some really good gear.
    All Naim gear (pre, amp, & cd player) Total $29K
    Speakers - $4.5K
    Was it good, you bet your life.
    My audio world is only about three years old, so another 2 years to build my 2 CH.
    Patience has always been on my side.
    Michael ;)
    NORTH of 60°
    VR3 Posts: 29,610
    I can say I have never had that problem - atleast not in the past year.
    Id venture to say its not important about price or "accuracy" or w/e - but finding a speaker that produces a sound that you like. And it dosnt really matter what you listen to, because you're always going to like that sound regardless..
  • madmax
    madmax Posts: 12,434
    Whenever that happens to me my system improves quickly. Normally I find that changing stuff around allows me to move up a notch. For example, speaker placement, rubber feet under a few components, cleaning up interconnect and speaker connections (usually just fumbling around with them) and other stuff I normally don't think about. With my particular preamp I found that feeding the CD into the tape-in rather than the CD input gave me a big jump upwards. Of course that was specific to my particular pre but you know what I mean. If I hadn't played around with it I would have never found that out. I bet there is a ton of potential sitting right in front of you that you may not have tapped into yet. Another thing is that it could have just been louder than your system. I once found that after listening to a better system that I was just trying to get too many decibles out of mine after returning home. Took me weeks to figure it out...
    madmax
    Vinyl, the final frontier...
  • janmike
    You are probably right madmax. I have played around a little trying to see how I could make it better. My problem is that I never seem to be able to go beyond speaker placement. Probably just a little inexperience on my part. I played around with the sub a little but I think it is definition and soundstage that I am missing. Then again, that's me and what I listened to a week ago is definitely better that what I have.
    Michael ;)
    NORTH of 60°
    VR3 Posts: 29,610
    What is your system??
    Soundstaging has alot to do with how far the walls are from your mains than anything if you ask me...
    Getting your mains away from rear and side walls will do more than you think.
    Tilting the speakers up, toe in... all that adds up...
    Crossover mods... spiking... seperate amp? preamp? cdp?
    Yada yada yada
  • Early B.
    Early B. Posts: 7,900
    janmike -- please describe your 2-channel system for us including room dimensions.
    A few months ago I went to see one of my favorite jazz artists and her trio at a small venue with good acoustics. Then I went straight home and played most the songs from the concert on my 2-channel system. I concluded that I wasn't missing anything at all.
    "God grooves with tubes."
  • madmax
    I too would be interested in what you have in your system. Maybe we could be of help.
    madmax
  • janmike
    The room is 18.5 X 14.5 with a 7.2 dropped ceiling. Carpet on the floor and is a dedicated HT / Audio room.
    Speakers:
    Front - RTi100's
    Centre - CSi5
    Rear - RTi6's
    SUB - REL Strata I
    RECEIVER - Yamaha RX-V1500 (Centre & Rears)
    AMP - Rotel RB-1080 (Front)
    CDP - Marantz SE67
    Cables:
    Analog Twos’s (Amp to Receiver & Marantz to Receiver)
    Ultra (Double Run) Single Wire (Front & Centre)
    MagicPower Digital/Video Power Cord (Yamaha)
    MagicPower Power Cord (Rotel)
    Fronts are 15" from the back wall & 12" from the side wall.
    Sub is 12" from the back wall near left front speaker.
    Listening postion is centred & 11' from the speakers. (Good for HT)
    All equipment is housed in open Plateau Audio Stands.
    Everything on the carpet has spikes.
    For HT it works great. It's the 2 CH thing that I would like to improve.
    Michael ;)
    NORTH of 60°
    VR3 Posts: 29,610
    Get your mains atleast 1.5 - 2 feet from side walls and 2 feet from rear walls...
    Tilt them up
  • audiobliss
    audiobliss Posts: 12,518
    ...and connect all cables properly.
    And never say I didn't contribute something.
    :D
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • janmike
    Other than describing all of the connections, anything that could be wrong that a lot of people may do.
    Speakers are being relocated..........
    Michael ;)
    NORTH of 60°
    VR3 Posts: 29,610
    Make sure they are toed in (play with that)... RTi really needs some toeing in...
  • janmike
    Sid,
    And by toeing I understand that to be the angle?
    Are you tilting the front (putting maybe 1" or 2" of wedging)?
    Michael ;)
    NORTH of 60°
    VR3 Posts: 29,610
    I tilt mine about .25" higher than the back....
    With about a 3-4" toe in (ex: 1' 6" from wall, back corner.... 1' 9" from wall, front corner...
    VR3 Posts: 29,610
    I go by the threads on the spikes personally - my front spikes are 4 threads higher than the back...
  • janmike
    I'll play with that a bit and will have to test tomorrow. The 6 year is asleep. Thanks.
    Michael ;)
    NORTH of 60°
  • ohskigod
    ohskigod Posts: 6,505
    maybe a tube pre with a home theater bypass? it would go from pre outs from the yammie, to the input of the bypass on the pre. output to the amp. when the bypass is on, then the reciever acts as the pre (for home theater) but for 2 channel, the tube pre will drive the mains only (keep the yammie off)
    have a feeling that would make a significant improvement in the 2 channel dept.
    Dodd ELP is the cheapest I can think of with the home theater byass (is an option for an extra 50? new)
    just throwing the idea out.
    even my outlaw 950, while great for home theater, isnt the greatest in the planet for 2 channel music (hence I have a seperate 2 channel rig)
    Living Room 2 Channel -
    Upstairs 2 Channel Rig -
  • janmike
    Actually I had thought about a separate, but will build the 2 Ch down the road. This will be all new gear. One thing I would like to do is to trade the 1080 for a 5Ch amp or add a 3CH amp for HT. That way the Yamaha is not driving any of the speakers. I do like the flexibility the Yamaha has for HT.
    Michael ;)
    NORTH of 60°
    F1nut Posts: 52,102
    LOL......now that you've got a taste, it's all downhill from here on out.
  • janmike
    Thanks Jesse, but it's a good downhill race.
    Michael ;)
    NORTH of 60°
  • phoneisbusy
    phoneisbusy Posts: 867
    :eek:
    You'll eventually dry out from the rain... Still got the Fidelity Aucoustics on your mind? ;)
    Does your Yammie have a direct mode for your cd player? There's a definite difference when I have it enabled on my Pioneer.
    Dave
    Time is the best teacher. Unfortunately it kills all its students.
  • janmike
    Yes it does. I find that mode sounds great. Only one problem, no sub in that mode.
    Hey Dave, if you are in the city drop by and have a listen to those FA speakers.
    Michael ;)
    NORTH of 60°
  • janmike
    I little positioning , a little tilting and things have improved somewhat. The mains are now a minimum 20" from any wall. The tilt is approx. 1/2". I know I missing that clarity that heard a while back. Appreciate all the suggestions guys.
    Michael ;)
    NORTH of 60°
  • phoneisbusy
    If I do get a chance to go downtown, I'll be sure to check out the FA(s). Too bad about the sub in direct mode. I was thinking the receiver's dsp options were mudding things up for you.
    Does the Yamaha have 5.1 or 7.1 direct inputs for SACD and such? Just wondering if a SACD with bass management would improve things (i.e. not sure, just speculating).
    Jesse, I respectfully disagree. It's now an uphill battle to afford the gear...
    :D
    Dave
    VR3 Posts: 29,610
    1/2" may be to much...
    Im sitting like 4-5 feet from mine and I only have an 1/8" tilt... - you shouldnt need some extroidinary amount of tilt unless your sitting like a foot away... (and my tweeter is BELOW the midbass)
    You can OVERSHOOT the tweeter...
    And Im not going to lie to you, I thought the tweeter in my RTi70 lacked all kinds of clarity and detail (and the midbass)... so Im not going to sit here and tell you that placement and equipment is going to change that.
    The biggest upgrade I did was get new speakers...Ive been complaint free since.
  • janmike
    I'll play around with the tilt portion a little more. I agree, the new speakers will change my 2 CH sound quality.
    Michael ;)
    NORTH of 60°
