mm455s
sntnsupermen131
kim,
what is the best rockford fosgate amp to go with the mm455s?
thanx,
cody
thanx,
cody
Post edited by sntnsupermen131 on
Thanks Kim,
Is this the amp you're talking about?
Rockford Fosgate Power 500.2
I found it for $299 at www.ikesound.com .
Thanks again,
Cody -
Kim, you there?
how much watts do these things handle?
250 seems like a little much...
-CodyTesting
Testing
Testing -
i was looking at the Rockford Fosgate 360.2
It puts out:
90 W X 2 @ 4 Ohms RMS @ 1% THD
180 W X 2 @ 2 Ohms RMS @ 1% THD
360 W X 1 @ 4 Ohms Bridged RMS
isnt 90x2 at 4 ohms enough??
especially since Rockford Fosgate amps are really under rated?
these speakers are rated 25-100 and the 500.2 is rated at 125x2 at 4 ohms
am i right here?
-Cody -
Yes, 250 x 2 would work- I've got a Zapco Reference 200 bridged 200 watts mono) to each MM465 in my kickpanels. The tweeters run off another Reference 200 running stereo.
But 90 x 2 would be enough, Kim just likes to recommend a little extra power. -
how much can these speakers handle?
per speaker...not total...
rms that is?
-Cody -
Wow those speakers handled a lot more than i thought...
the specs next to the speaker said 25-100 watts so thats where i got confused
thanks a million for all the advice...I'm going to go with the 500.2 and hopefully have everything set up within a month?maybe...
Thanks again,
CodyTesting
Testing
Testing -
oo and one more thing...
i went on a website(Forget which one) and it said the 500a2 had been discontinued--do you know why?
-Cody
