Lsi9 with NAD T752 Reciever
prozach7
prozach7 Posts: 1
edited February 2006 in Speakers
This is my first post but have been a lurker for a while.
I just hooked up the lsi9's to my NAD reciever and it sounds good. However, everyone who said you need more power is right!! The amp is rated at 90w in 2 channel mode and the speakers just start to perform near full power. I like my music loud so that may have something to do with it. I know the amp is putting out a lot of power because the lights in my room dim with every bass note. So if anyone has a good deal on a 2 channel amp let me know($300-500). I still plan on using the reciever for HT, but like music louder.
Question. Does bi-amping the speakers make a large difference?
Zach
Post edited by prozach7 on
  • nebborjk
    nebborjk Posts: 425
    It should not be to difficult to find an amp in your price range that will do a better job driving those Lsi's, assuming you don't mind buying used.
    Search Audiogon.com for brands like Adcom, B&K, Parasound, Rotel and Outlaw.
    The benefits are bi-amping are debatable. I wouldn't worry about it right now.
    Proud SOPA Member since 2005!
  • pjdami
    pjdami Posts: 1,894
    Hey Prozach7, welcome to the forum. That 2 X 90 watts is for 8 ohm speakers. Since your LSi are 4 ohm then you can almost double that power for that receiver. Remember you need to double the power in watts to get a 3 db output change and that receiver is probably putting out 150 watts into 4 ohms already. Do you know how loud you are listening in dbs?
  • pjdami
    pjdami Posts: 1,894
    If you want to experiment around, here is a good amp on the Flea Market for sale:
    http://www.polkaudio.com/forums/showthread.php?t=37239
  • ohskigod
    ohskigod Posts: 6,502
    careful going loud with that reciever. clipping = blowing speakers, easier to do when a speaker is underpowerred than over powerred. keep the listening levels moderate until you step up the amplification.
    add the Carver 4.0, tfm42, or tfm45 (all the same amp) to your list of potentials. a little pricey used (400 ish) but it sounds downright magical with the LSi9's. thats what I have playing right now and the sound coming from these little bookshelfs has been very impressive. Everyone I let listen to it is friggin amazed.
    it goes loud and clean. 500 watts at 4 ohms is apparently a good thing for the LSi9's
    Living Room 2 Channel -
    Schiit SYS Passive Pre. Jolida CD player. Songbird streamer. California Audio Labs Sigma II DAC, DIY 300as1/a1 Ice modules Class D amp. LSi15 with MM842 woofer upgrade, Nordost Blue Heaven and Unity interconnects.
    Upstairs 2 Channel Rig -
    Prometheus Ref. TVC passive pre, SAE A-205 Amp, Wiim pro streamer and Topping E50 DAC, California Audio Labs DX1 CD player, Von Schweikert VR3.5 speakers.
    Studio Rig - Scarlett 18i20(Gen3) DAW, Mac Mini, Aiyma A07 Max (BridgedX2), Totem Mites
