What's the big deal with Oppo
Willow
Willow Posts: 11,233
edited February 2006 in Electronics
I have seeing this player everywhere. Is it hype or should someone looking for a dvd player jump on this bandwagon like everyone does with SVS?
I am being honest about knowing if this player is worth it..with a Bday in 2 months and wanting a better player than I have.......
Post edited by Willow on
  • MSkeezer
    MSkeezer Posts: 1,183
    Yeah I'm curious too. I want a new dvd player and not just some cheapo POS. This Oppo player seems like a good deal. I'm also looking at the Cambridge DVD55 player for $200 from Audio Advisor...
  • izafar
    izafar Posts: 819
    I have this for a couple of months. Video quality is top notch via DVI output (Actually it is 2nd to only Denon DVD-5900 which sells for $3500). Build quality is what you can expect from a $200 player, and the remote sucks.
    I have heard that Oppo cust support is great and they regularly post firmware upgrades to fix issues or add features.
    The player also supports DVD-Audio but I haven’t yet tried that.
    -izafar
    Goldenear Technology Triton 1 - Benchmark AHB2 - Benchmark LA4 - Auralic Vega - Auralic Aries Mini - Marantz TT-15S1 - Clearaudio Nano
  • Willow
    I'll have to be sure Harmony 659 can work with it ?!
    Did you try component? I would probably use either DVI/HDMI, but in case.
  • PolkThug
    PolkThug Posts: 7,532
    Willow wrote:
    Go to the Secrets of Home Theater Hifi website for all the test details.
  • drew spelts
    drew spelts Posts: 310
    The problem with the player is that it can not up-convert via Component cables, only through DVI.
    Harman Kardon AVR635
    RTi10's Up Front
    CSi5 Center
    RTi6's Rear Surround
    Furman RA-1210:rolleyes:
  • Willow
    I've got a free slot in my TV :D
  • BIZILL
    BIZILL Posts: 5,432
    yes harmony works with oppo. yes it's worth it. yes i go through dvi. yes they do regular upgrades. no, i wouldn't buy. i'd wait for hd-dvd.
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    7.1 SURROUNDS: RTI6'S
    XBOX 360
    WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
    http://polkarmy.com/forums/index.php
    bobman1235 wrote:
    I have no facts to back that up, but I never let facts get in the way of my arguments.
  • louhamilton
    louhamilton Posts: 209
    I agree with BIZILL on all except the wait for HD-DVD. The format war is still flaming hot and I would not spend the money yet for a device that may not be supported (look at BetaMax). As an interim DVD player that will make most of your current DVD's look better, the Oppo is a good buy. I have been very happy with mine. I do not plan on being an early adopter of the HD-DVD/BRD formats.
    my 2 cents.
    -Lou
  • drew spelts
    What kind/quality of DVI cable do you use Lou. I want to know if monster is that much better at transfering the signal than standard DVI cables. If I get this DVD player then I have to invest in a DVI cable and thats going to cost me around $40 at least for a good one if there is such a thing.
    RTi10's Up Front
    CSi5 Center
  • louhamilton
    I have a Monster that I was able to get dirt cheap (BB Open package discount). I also have the one that came with the Oppo. I have compared the two and see NO DIFFERENCE.
    Not sure if Oppo is still offering the DVI-HDMI cable, but they do provide a DVI-DVI. You could just pick up a DVI-HDMI adapter for about $15-20 if you need HDMI.
    -Lou
  • PolkThug
    I had the Monster high end one and one from a computer store. I sold the Monster, no difference, and I am very picky about PQ.
