Monitor 30 for Surround Sound ????
*Seby*-Polk-
*Seby*-Polk- Posts: 375
edited February 2006 in Speakers
Hi Everybody !!!!
I need our help (my english is not good...) I purchased a set of Monitor 50 recently. I'm impressed with de sound at any volumes. Very Clear, crisp and loud. I tested with a Yamaha NS 555, JBL E60 and Infinity Primus. The results:
* Very superior to Yammie's (no comparisson) :D
* Superior to JBL (more clean and more crisp) :D
* Little superior to Infinity (same quality..a bit best Polk) :D
I tested with dance, rock, power metal, ballad, clasical music and R&B.
The winner is Polk. (and looks great) :cool:
My question is, the Monitor 30....is a good set of Surround Speakers (relation price-quality) ??? Or there are other options in other brands ????
Thanks Everybody !!!!!!! :)
My current new system (step by step :D)
A/V Receiver: YAMAHA RX-V657
DVD Player: YAMAHA DVD-S657
Main Towers: polkaudio® Monitor 50
Wiring: NeoTecH KS1007 OFC High Definition Speaker Cable ( 2 x 2.64 mm² )
  • zombie boy 2000
    zombie boy 2000 Posts: 6,641
    go with the 30's, as they are timbre matched with the 50's -- you won't be disappointed!!!!
  • crazy
    crazy Posts: 443
    Monitor 30's are great with the Monitor 50's - make sure you get the CS1 (or CV2) and the matching sub - PSW10 or PSW20, though from the forum it seems that you can get any sub and you'll be fine.
    Distant Dream - A New Beginning
    www.distantdream.com
    (Now also available on iTunes)
  • *Seby*-Polk-
    OK. I test Monitor 30 as surround speakers. CS1 or PSW 10/12 ??? What buy first ???
