Looking for specs for 1991 Polk
OU4LIFE
Monitor series 2. They are 2-way bookshelf size. with a 4" driver and a tweeter.
I'm looking for specs on the 4" driver if anyone has any ideas. The back of the driver says MW4000.
a forum search just brought up a bunch of the larger speakers.
thanks all.
mark
thanks all.
mark
Post edited by OU4LIFE on
Looks like the monitors are part of the old Monitor 6 setup. Came with a sub box and the 2 monitors.
One of the 4" drivers I have is bad, and I need to replace it, but I need the specs to make sure I get something the same.
thanks -
Call Polk Customer Service. They might have a replacement.
Welcome to the forums.
Here is a look at the smaller Monitor Series 2 speakers from around '91. -
The only old Sub/Sat Sytem that I can find specs on right off the bat is the 4/14 three piece system using the Monitor 4. None of the speakers so far uses a 4" driver though...
Hey Bob, where'd you get those info sheets?
Look here:
http://clubpolk.polkaudio.com/service/models/modelpartslist.php3?model=monitor
They show a Monitor 6 Sat/Sub that had the MW4000 with an SL1500 tweet. I'm just not sure they are 1991. -
michael_w wrote:Hey Bob, where'd you get those info sheets?
I've had 'em a hundred years... ...wait... that couldn't be, could it?
Oh well, you get the idea.
thanks bob. it was these: http://www.polkaudio.com/homeaudio/products/monitor6/
but note the lack of specs for the mids. It just gives overall range of specs for the set of three.
thanks all.
