direct stereo
bigsslim
I have 3 options on my yamaha for stereo, 7ch stereo, 2ch stereo, and direct stereo. I understand the first two, could someone break down (direct stereo) like a shotgun.
F-lsi9
C-lsic
Sur-lsifx
Sur-B-lsi7
Sub-psw10
PRS custom 24 20th
yamaha5790
yamahaC940sacd
monster 14G
C-lsic
Sur-lsifx
Sur-B-lsi7
Sub-psw10
PRS custom 24 20th
yamaha5790
yamahaC940sacd
monster 14G
Post edited by bigsslim on
Direct stereo bypasses your bass, treble, and balance settings for a "direct" transfer of sound from your source.
As clean and straight as you can get without going directly from the source directly to the amp. As polk65 says plus sometimes they eliminate some of the switching circuits the signal goes through as well.Vinyl, the final frontier...
My system has even an additional setting called pure audio. It is basically the same as Direct Audio but switches off all the LED and non-used electrical systems in the receiver so not to introduce any distortion into the sound.Holydoc (Home Theatre Lover)
__________________________________________
Panasonic -50PX600U 50" Plasma
Onkyo -TX-NR901 Receiver
Oppo -Oppo 980HD Universal DVD Player
Outlaw -770 (7x200watt) Amplifier
PolkAudio - RTi12 (Left and Right)
PolkAudio - CSi5 (Center)
PolkAudio - FXi3 (Back and Surround)
SVS - PB-12/Plus (Subwoofer)
Bluejean Cables - Interconnects
Logitech Harmony 880 - Remote -
I may be a little rusty so someone correct me if I'm wrong.
I believe on that series of Yamahas, when running in "2ch stereo" it would still leave your bass management settings in effect. So if you mains were set to small your sub would still handle the low frequencies. However when in "Direct Stereo" mode, in addition to bypassing tone and balance controls, it would also override your bass management and just run the two front speakers full range without the sub.
On the newer models such as my RX-V2500 they now offer a Pure Direct mode much like the Denon, and Onkyo. This does basically the same thing as Direct Stereo but also turns off all video switching circuits, front display, and any unnecessary processing in the attempt to minimize interference.
I think I remembered that properly. Been a while since I messed with the older models.
Happy Listening!
DaveHT
Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
2 CH
Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500, -
is it like a source-direct button ??ELECTRONICS
arcam cd93
linn wakonda
MC2 MC450
Teac ud h01 DAC
SPEAKERS
Tannoy DC6 t se . -
yes, it is a source direct button.
Yes. The "pure direct" mode make the sound clean as possible.
My question is .... You can adjust bass treeble level in pure direct mode (Yammie)
Thanks !!!!My current new system (step by step)
A/V Receiver: YAMAHA RX-V657
DVD Player: YAMAHA DVD-S657
Main Towers: polkaudio® Monitor 50
Wiring: NeoTecH KS1007 OFC High Definition Speaker Cable ( 2 x 2.64 mm² )
