Subwoofer
kmartin971
I currently have a polk subwoofer. I want to upgrade. Any suggestions for an LSi system?
TV = WS65611
Pre-Amp Onkyo 830
Amp Aragon 2007
Panamax 5510
Towers = LSi25s
Center = LSiC
Side Rear (2) = LSiFX
Rear (2) = LSiFX
JBL S120P II
Sony Upconverting DVD Player
XBox
XBox 360 (Wireless connection live and media center enabled)
PS3
Pre-Amp Onkyo 830
Amp Aragon 2007
Panamax 5510
Towers = LSi25s
Center = LSiC
Rear (2) = LSiFX
JBL S120P II
XBox
PS3
Post edited by kmartin971 on
Well, before you get a hundred SVS suggestions, let me at least suggest auditioning some Martin Logan subs. They make, in my opinion, some of the best subs available. Deep, rumbling, visceral impact for movies, but tight, accurate and full sounding for music. Truly the best of both worlds. A Grotto is a single 10", goes to 22Hz and has a lot of force for a small to mid size room. A larger room, such as 15x20 or larger, could use a step up to the Depth, 3 8" drivers in triangular array-cancel each other's backward bass to create an inert box and very accurate sound. No messy boom or bass lag with these subs.
Grotto runs $1000, Depth $1750. Try to find a local dealer to check them out. The Magnolia Home Theater in Best Buy should at least have the Grotto on display, however there may be full-line dealers near you too. I had an SVS PB 10 ISD, and while it was great for movies, it lacked that tightness and accuracy I was looking for in music playback. In my humble opinion, this is indicative of most ported subs, which ML's are not.
Check out http://www.martinlogan.com/ to get more details on the subs and dealer locations.
Another plus to the ML subs is that they are not your usual big box shape, making them actually quite attractive, and they are relatively small, helping to save space in the room and help the spousal acceptance factor. SVS subs are practically end tables.Current System:
CSi5-Center (for sale**)
FXi3-surrounds (for sale**)
Martin Logan Depth-Sub
B&K AVR 507
Pimare CD21-CD Player
Denon 1815-DVD Player
Panamax M5500-EX-Line Conditioner -
i getting ready to buy the really big polk sub box the 212's it is rated at 750 watts and 1500 peak whats that mean also what size amp will i need to drive them right and does polk make one or do i need 2 500 watt momo'sJohn Tyler Birch
home audio system:
Denon avr-1907
Sony dvd/cd changer 5 disc
nakamichi BX-100 tape deck
2 Polk Audio monitor 70's
Velodyne DPS-12 subwoofer
RCA TV
NAK 600 tape deck
Monster power line conditioning power center -
Any suggestion for a good sub for the LSi series for HT use?TV = WS65611
Pre-Amp Onkyo 830
Amp Aragon 2007
Panamax 5510
Towers = LSi25s
Center = LSiC
Rear (2) = LSiFX
JBL S120P II
XBox
PS3
