Amps for 6 ohm speakers
Ricardo
Ricardo Posts: 10,636
edited January 2006 in Electronics
Ok; so I got these speakers that are rated at 6 ohms; I did not even think about the convenience or not of that rating...until now.
Many amps have a switch or separate binding posts to select 4 or 8 ohm speakers; I've seen this more in tube amps.
So, what if the speakers are 6 ohms? What would the right setting be for the amp if it only has 4 and 8 as options? What are the risks of damaging either the speakers or the amps?
Would like to know what you experienced people think about this.
Thanks!!
SOPA
  • gregure
    gregure Posts: 871
    edited January 2006
    Honestly, most amps these days, apart from tube, don't have the 4/8 switch, and simply output the power required. I would think with 6 Ohm speakers that a non-switchable amp would be a better choice. However, if required, I would assume a 4 ohm selection to be better, since the speaker will regularly drop to 4 ohms, but not likely spike to 8 on a regular basis.
    Current System:
    CSi5-Center (for sale**)
    FXi3-surrounds (for sale**)
    Martin Logan Depth-Sub
    B&K AVR 507
    Pimare CD21-CD Player
    Denon 1815-DVD Player
    Panamax M5500-EX-Line Conditioner
