Good deal on PS Audio power cords
F1nut
Audio Advisor is having a trade in sale on the fantastic PS Audio Statement power cords. You buy at full price, send back ANY power cord and they refund half the purchase price. This one is a no brainer folks.
http://www.audioadvisor.com/store/productdetail.asp?sku=PSASTPC1&loc=4
Post edited by F1nut on
How does a $400.00 power cable sound better than stock? You still have cheap romex going to the breaker box.
Well Jeff, you heard my set up. Granted, the dedicated 20 amp line run with high quality 10 gauge wire didn't hurt either. A high end pc will filter out RF and EMI that a stock cord can't and seeing as this one is 6 gauge, it doesn't act as a choke like a stock 18 gauge pc will.Political Correctness'.........defined
President of Club Polk -
warlocks1 wrote:How does a $400.00 power cable sound better than stock? You still have cheap romex going to the breaker box.
I'm not sure about a $400. cord, but I can tell you the $60.00 PS Power Punch that came with my CD player made a hudge improvement. I used the standard round computer type cord that was packed with the player at first because the PS cord required a big hole being drilled through the back of my cabinet and I was to lazy to remove all the equpt. and drill. But when I did it was shocking to say the least -
Even with the trade in they are overpriced.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
dorokusai wrote:Even with the trade in they are overpriced.
Yep.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Bah, humbug to you too.
For those that may think like Doro and Early, this would be a great chance to try it for yourself, you know, form your own opinion from actually using it in your system before passing judgement. At these prices you aren't going to lose money reselling it, that's for sure.Political Correctness'.........defined
Are you guys against good power cords in general or just those particular PS Audio cables?
A power cord ain't that complicated. Personally, (and I've been known to be wrong) I just can't believe a $400 PC is any better than a $100 PC.2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones
Seriously... when can a power cable EVER be worth $450? or even $225???
I can think of a lot better ways to spend that money... and if you can't, I think you can just send it directly to me and I'll use it in better ways, for you.Ludicrous gibs! -
dragon1952 wrote:A power cord ain't that complicated. Personally, (and I've been known to be wrong) I just can't believe a $400 PC is any better than a $100 PC.
It is, in my opinion. But the cost for Statement power cords is too high at full retail to be justifiable for me to use except from power conditioner to wall. I use one from a PS Audio Power Director 4.7 to the wall, and use Plus and Preludes on everything else in my home theater system. The differences between using stock to DIY type to PS Audio products were substantial. The best performance per dollar is probably the Plus if paying full retail (I don't). The Preludes aren't much more expensive than offerings from DIY design companies, but I've found the build quality to be much superior with the PS Audio products.
If anyone gets a Statement cord, I'd suggest at least a 1.5 meter length. The cords are very thick and inflexible, and anything shorter than 1.5 meters causes routing problems. The cord design causes it to stick out pretty far from the wall socket too. -
Nm...CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
madmax wrote:Are you guys against good power cords in general or just those particular PS Audio cables?
madmax
This was a serious question. I was considering the PS power cords unless someone thinks there is something wrong with them. Is it the PS cords or the idea of power cords making a difference in general?
There's nothing wrong with PS power cords, if there was I wouldn't have posted the info. In addition to a well built cord these guys went to the trouble to make both ends bulletproof and unlike any other on the market at any price. I use them and highly recommend them.Political Correctness'.........defined
I use Zu PC's as well as the Signal Cable MagicStrip I just think that there's a point of diminishing returns price-wise. Nothing against PS, they probably make great stuff and that's probably a pretty good deal if you don't mind spending the bucks. The description sounds like they've put a lot of thought into it.madmax wrote:This was a serious question. I was considering the PS power cords unless someone thinks there is something wrong with them. Is it the PS cords or the idea of power cords making a difference in general?
madmax2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones -
Yep, that is a "no-brainer".
I love upgraded PC's but large gauge copper is all I'll pay for...the rest is just fluff. I found ZERO difference in using PS Audio products in this application over my Signal Cable. The Humbuster is a nice product, actually worked and is more reasonably priced, but I sent that back as well.
If F1 says he believes in PS Audio, I believe him. He's educated enough to know that he found them to be a benefit in his rig and they are built very well.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
I just purchased an engine kit for a smallblock chevy,it came with everything,pistons,cam...I mean everything...$324 before shipping.$400 for a cable...WOW!
RuSsMaN wrote:It does however lean toward the audio 'voodoo and doodoo' section for me.
Cheers,
Russ
I certainly do not doubt their quality,just out of my price range for a power cordF1nut wrote:There's nothing wrong with PS power cords, if there was I wouldn't have posted the info. In addition to a well built cord these guys went to the trouble to make both ends bulletproof and unlike any other on the market at any price. I use them and highly recommend them. -
You have a power source in your wall, how you want to tap into it is up to you.
Cheers,
madmax
Yes, I'm against ALL power cords. I'm heading home tonight and throwing them all in the trash!No excuses! -
I know I am always pushing Raymond Cables but I really like them.
I believe cables make a difference but I also believe in diminishing returns therefore when the time came for new power cords I went with these.
Raymond Cable Stainless theater power cords.
For the money I think they can't be beat. He will also make any length you want.
I just ordered 2 more and got both 4.5' long stainless wrapped cords for $158.00+/- shipped.Skynut
SOPA® Founder
The system Almost there
DVD Onkyo DV-SP802
Sunfire Theater Grand II
Sherbourn 7/2100
Panamax 5510 power conditioner (for electronics)
2 PSAudio UPC-200 power conditioners (for amps)
Front L/R RT3000p (Bi-Wired)
Center CS1000p (Bi-Wired) (under the television)
Center RT2000p's (Bi-Wired) (on each side of the television)
Sur FX1000
SVS ultra plus 2
www.ShadetreesMachineShop.com
Thanks for looking -
madmax
I use a PS Audio Prelude on my Jolida and it works great. Very high quality and I recommend then without hesitation. I just think spending $200+ on a power cord is too much dough. Hell, I only paid $200 for my Monster 3600 power center, so I ain't gonna pay the same amount for a freakin' cord that plugs into it.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
OK, here is proof that they are worth it:
"Improvements in openness are stunning. The top end of your AV setup will come alive in a way you never thought possible. The noise floor is dramatically decreased, while the slam and impact of the bass are substantially improved"
Straight from AA...
I think AA has nicer looking models than MusicDirect, so that seals the deal for me.
Actually, F1 made folks aware of 50% off deal, thanks Jesse!!! Buy what you want.
RT1 -
Hearing is believing! I say before anyone poos on these cords they should try them. I haven't, but I'd like to keep and open mind. Buy two, one moderately priced and one more reasonably priced. Try them in your system and see if you like what you hear. Don't forget to check the return policy. I'm sustect of any company that won't fully refund your money. Especially cables, any kind.
Thanks for the heads up Jesse!
Thanks to the contributors too! Good discussion.Carl -
Thanks for the heads up Jesse! I have a 2M on order for the phono pre. (or somewhere else if it sounds better there).
Just received my order today, burning in as we speak. Nothing stunning to report as I already have a number of them and am quite familiar with their characteristics. I did forget to mention AA offers free shipping with the deal too.Political Correctness'.........defined
I've been meaning to order some from my local dealer, cool.
What are you sending back? A grunt stock IEC?Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service. -
That`s what I would do..
send back el cheapo, and get el good-oCary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool:
