Help with fronts and surrounds
chrisrud15
chrisrud15 Posts: 48
edited February 2006 in Speakers
Okay after reading posts im throwing the r15 and the r30's out the window. Im now either going for some rti's: either the 4,6 or the old 38's or 25's. I would rather spend the extra $$ now than have to upgrade again. Another option would be to add the satellite surrounds that the 6800 system uses to my CS1, PSW10, with Onkyo 7.1 channel receiver. Any thoughts on the 6800 satellites. I can get all 4 and use 2 as fronts and 2 as rears. Thanks
HT- CS1, Infinity 12 in. sub, Onkyo receiver, m20's, and m10's
Car- Polk MOMO 6500 components, alpine 2 channel amp, Pioneer HU, Infinity Kappa Perfect 10 in. sub, Diamond Audio amp
  • ohskigod
    ohskigod Posts: 6,505
    edited January 2006
    use the 4 sattelites as surrounds only. use the rti4 or 6 as mains. the CS1 as a center. I think thats the best way to lay out what you got, or almost got.
    Living Room 2 Channel -
    Upstairs 2 Channel Rig -
  • *Seby*-Polk-
    *Seby*-Polk- Posts: 375
    Hi Chris
    Try the polk monitor 30 as surround sound. It's cheap but great performance.
    If you get extra bucks, try monitor 40...with double woofer. But the sound quality is the same...is POLK !!!!
    My current new system (step by step :D)
    A/V Receiver: YAMAHA RX-V657
    DVD Player: YAMAHA DVD-S657
    Main Towers: polkaudio® Monitor 50
    Wiring: NeoTecH KS1007 OFC High Definition Speaker Cable ( 2 x 2.64 mm² )
