Should I use R30's as rears??
dapunkster
dapunkster Posts: 6
edited January 2006 in Speakers
I have RT55i's as my fronts and CS400i for the center. I see that Fry's has the R30's cheap right now and I am looking for some rear speakers. Would anyone recommend this as a possible set-up??
Post edited by dapunkster on
  • adam2434
    adam2434 Posts: 995
    edited January 2006
    While they are not a match and are not in the same league as you other speakers, they would still work OK for surrounds (maybe until you could find some FX500i's, RT25i's, etc,)
    My question or concern would be how you get them to the proper height for surrounds? They are pretty short towers, and I've always put my surrounds about 6-7 ft. up on the wall.
    5.1 and 2.0 ch Basement Media Room: Outlaw 975/Emotiva DC-1/Rotel RB-1582 MKII/Rotel RB-1552/Audiosource Amp 3/Polk LS90, CS400i, FX500i/Outlaw X-12, LFM-1/JVD DLA-HD250/Da-Lite 100" HCCV/Sony ES BDP/Sonos Connect. DC-1/RB-1582 MKII/Sonos Connect also feed Polk 7C in garage or Dayton IO655 on patio.
    2.1 ch Basement Gym: Denon AVR-2807/Klipsch Forte I or NHT SB2/JBL SUB 550P x 2/Chromecast Audio.
    2.0 ch Living Room: Rotel RX-1052/Emotiva DC-1/Klipsch RF-7 III/Sony ES BDP/LG 65" LED.
    2.0 ch Semi-portable: Klipsch Powergate/NHT SB3/Chromecast Audio.
    Kitchen: Sonos Play5.
  • ohskigod
    ohskigod Posts: 6,505
    edited January 2006
    they'll work,, timbre matching for the surrounds isnt nearly as important as it us for the center and mains.
    you can allways put something to elevate them if needed. If its cost effective over other options you have, then go ahead and get em.
    Living Room 2 Channel -
    Upstairs 2 Channel Rig -
