Need advice please!B&W ASW 1000
brentski
brentski Posts: 96
My old JBL DPS-10 started to just hum a few weeks ago. I've tried everything short of opening the thing up but no sound,just a hum,like there's a short in the amp.
I've been 'testing' a Polk PSW12 for the past few weeks but am not too impressed.
There's a B&W ASW 1000 for around $250 available.(8-9 of 10)
All I know about it is what I've read on the web(which seems pretty good)
It'll be used primarily for HT use.
I figured I'd get some good,honest opinions here about this sub.
Any help would be greatly appreciated.
Thank you,
Brentski
Center; CS-400i
Main's; RT-55's
Side Surround's-RT-35's
Rear center;CS-300
Sub; SVS PB12-NSD
Post edited by brentski on
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited January 2006
    Great price on that sub. You've certainly got room to get out of it, should it not blow your skirt up.
    Give it a shot in your rig.
    Cheers,
    Russ
  • brentski
    brentski Posts: 96
    edited January 2006
    I'm not sure what you mean. Guess I don't know the Polk lingo.
    Could you please explain what you mean by;
    "You've certainly got room to get out of it"
    Again,your help is appreciated
    Thanks,
    Brentski
    Center; CS-400i
    Main's; RT-55's
    Rear center;CS-300
    Sub; SVS PB12-NSD
  • RuSsMaN
    edited January 2006
    You are buying it 'right', ie not paying too much. You've got 'room' ( $ ) to sell it and if not make a little money, at least recover your investment, should you not care for it's performance.
    Cheers,
    Russ
  • brentski
    brentski Posts: 96
    edited January 2006
    This speaker is about 6 yrs old.
    Is there any reason that I should shy away from getting an older speaker such as this due to the fact that something might go wrong with it?
    The reason I'm concerned about this is the reason why I'm looking for a new sub to begin with.
    My JBL sub (that just quit working) is about 6-7 yrs old.
    I'm going to take a look and listen tomorrow.Is there anything that I might look for in an older item such as this?
    Again, any help is appreciated.
    Thanks,
    Brentski
    Center; CS-400i
    Main's; RT-55's
    Rear center;CS-300
    Sub; SVS PB12-NSD
  • dorokusai
    dorokusai Posts: 25,638
    edited January 2006
    Yea, make sure it works.
    Finding Nemo - Darla, for the demo....if it flaps it's surrounds like a Sunday night ****, walk.
  • beardog03
    beardog03 Posts: 5,550
    edited January 2006
    wwwwwwwaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    don`t walk....run..!!
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • schwarcw
    schwarcw Posts: 7,360
    edited January 2006
    :eek: :eek: :eek:
    Carl
