50 foot sub cable
whitetruk
whitetruk Posts: 308
any thoughts on this would be gratefull.my music room might call for this.that would be an rca cable thank you.
scott e
I thought it was fairly amusing also. The Polk Ogre doesn't always get 'it'
Post edited by whitetruk on
  • John K.
    John K. Posts: 822
    edited January 2006
    Whitetruk(hope that isn't where you got your speakers!), a 50 foot cable to connect to a sub doesn't present a significant technical problem and cables as good as any are available at quite low cost, such as this one from Triangle Cable .
  • adam2434
    adam2434 Posts: 995
    edited January 2006
    Here's another option:
    http://bluejeanscable.com/store/subwoofer/index.htm
    50 foot options will be pretty limited.
    Also, you may want to do some research on any potential loss/degradation in such a long run.
    5.1 and 2.0 ch Basement Media Room: Outlaw 975/Emotiva DC-1/Rotel RB-1582 MKII/Rotel RB-1552/Audiosource Amp 3/Polk LS90, CS400i, FX500i/Outlaw X-12, LFM-1/JVD DLA-HD250/Da-Lite 100" HCCV/Sony ES BDP/Sonos Connect. DC-1/RB-1582 MKII/Sonos Connect also feed Polk 7C in garage or Dayton IO655 on patio.
    2.1 ch Basement Gym: Denon AVR-2807/Klipsch Forte I or NHT SB2/JBL SUB 550P x 2/Chromecast Audio.
    2.0 ch Living Room: Rotel RX-1052/Emotiva DC-1/Klipsch RF-7 III/Sony ES BDP/LG 65" LED.
    2.0 ch Semi-portable: Klipsch Powergate/NHT SB3/Chromecast Audio.
    Kitchen: Sonos Play5.
  • whitetruk
    edited January 2006
    thanx for the info people.
  • labrat
    labrat Posts: 120
    edited January 2006
    I have a run about that long with a composite video going to a tv and don't detect any signal degradation. The cable is a rg6 (same stuff you use for antenna, cable or sat) with the appropriate adaptors at each end. Should work just as well for a sub.
    Scott
  • Polk65
    Polk65 Posts: 1,405
    edited February 2006
  • beardog03
    beardog03 Posts: 5,550
    bettercables.com
    I got one with my SVS...good solid cable...fair price also
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • labrat
    labrat Posts: 120
    Polk65,
    Nice looking cables, kind of makes me want to redo mine even though I am happy with the performance of the current one.
    Scott
  • Polkitup2
    Polkitup2 Posts: 1,623
    I have my SVS sub connected through 50 feet of inwall RG6 coax which is then connected to a 12 foot monster subcable which is then connected to an old component video cable I had laying around and it sounds the same as when I connect the sub directly to the reciever with the 12 foot sub cable.
  • amulford
    amulford Posts: 5,020
    My vote is for Bluejeans cables. I have 2 35' runs, they work well...
