Blown!!!!
fortytha12gauge
fortytha12gauge Posts: 47
edited February 2006 in Car Audio & Electronics
I blew my mm2124 dvc. can i send it to get replaced to polk? It was playing around 450 wats.
Shadow Inc records
Post edited by fortytha12gauge on
  • PolkThug
    PolkThug Posts: 7,532
    edited January 2006
    Should they replace the sub that you overpowered?
  • PoweredByDodge
    PoweredByDodge Posts: 4,185
    edited January 2006
    450 isn't really overpowering dude... its reasonable power for the speaker provided it was in a 0.88 cubic foot sealed enclosure.
    The Artist formerly known as PoweredByDodge
  • fortytha12gauge
    edited January 2006
    Wasn't overpwered! Its rms is 400 watts and its max is 800 watts. wasnt even close, alot of reveiws ive read has had the same issue i had. But i went out on a limb and bought these becouse of the good things ive herd about there customer service.
    Shadow Inc records
  • MacLeod
    MacLeod Posts: 14,358
    edited January 2006
    What issues? Im overpowering my MM2104 by nearly 100 watts and its working just fine.
    Call CS. If you bought it authorized theyll take good care of you.
    Customer Service:
    polkcs@polkaudio.com
    9am - 6pm, M-F, EST (USA)
    800-377-7655 toll free phone
    410-764-5470 fax
  • PoweredByDodge
    edited January 2006
    400 rms / 800 max does not mean you can put 800 rms into it.
    400 rms IS 800 max... max = peak.
    wattage = voltage squared / resistance.
    rms wattage = 0.707 * 0.707 * voltage squared / resistance.
    0.707 * .707 = 0.5 ... so half.
    therefore... 450 rms is 900 peak.
    so you were overpowering the speaker.
    and don't argue with me, i'm not explaining it any further, get a clue.
    however, years of experience tell me that if the new momo is more like the generation 1 and 2 momo, then you can probably dump 5 or 600 watts on it.
    if it's more like the old DB and DX stuff, then even though its rated at 400, you shouldn't break 350 on it.
    take it, chew on it - and call polk you turkey, 1-800-whatever polk's number is. if you ahve a receipt and you bought it from a real store or crutchfield or sounddomain, i'm sure they'll take care of you -- if you bought it from tony the fish at the flea market then forget about it, you can choke on it.
  • fortytha12gauge
    edited January 2006
    How tha hell im suppose to kno that so chill. im semi new to this.w/e got it from sonddomain still got recipt and all. so appreciate all the help.
    Shadow Inc records
  • MacLeod
    edited January 2006
    Its not always a point of using too big an amp. You couldve also had the gains set too high and momentarily clipped the amp sending about 900 watts to the 400 watt sub and subsequently killed it.
    Or you couldve just had the bad luck of buying a lemon. It happens from time to time to everybody.
  • fortytha12gauge
    edited January 2006
    I had two of em hooked up. it only got one of them "thank god" I had two jl w1v2 before these and they were 8 ohm. and those fried yea those were over powerd no dobt but the guy at the shop said i would be fine. ive had the amp for almost three years now. its doin me good. and the polk are the best ive had out of mtx rockford jl and crossfire
    Shadow Inc records
  • MacLeod
    edited January 2006
    Something sounds fishy to me. An 8 ohm sub wouldve been getting HALF what the Polks were getting so they shouldnt be blowing. What amp are you running? Something else could be wrong.
  • fortytha12gauge
    edited January 2006
    ive been told that a few times. Im currently runing a kenwood kac-7201. good look finding specs from the site i cant find them there. i had them bridged at 450x1 rms. the jl were svc and the polk were dvc.my fuses on my amp were blown both times this has happend. the jl had to be bridged to function. and i have the polks wired right.
    Shadow Inc records
  • MacLeod
    edited January 2006
    If the fuses on the amp were blown then your problem isnt with the speakers. The first thing you should check is your wiring. Is your power wire fused before the firewall?
    Even if it is, it could be arcing somewhere between the firewall and the amp and sending a pretty large surge to the amp. Your amps fuses could pop but not before your amp makes a pretty big burp of power and that could be the culprit.
  • PolkThug
    edited January 2006
    OK, something isn't right. If you're running two Polk 12"DVC's, they should be wired for a 4ohm load, and run the Kenwood bridged at 460x1 at 4ohms.
    I think you've got your subs wired for a less than 4ohm load. I've got the 7201 and its a great amp.
  • MacLeod
    edited January 2006
    If I remember right, this came up in an eariler post and he has them wired right. Theyre DVC subs and he has each sub wired in series and then both wired in parallel with the amp for a 4 ohm mono load.
  • fortytha12gauge
    edited January 2006
    the fuse is before. i have a power cap sorry left out.
    Shadow Inc records
  • PolkThug
    edited January 2006
  • fortytha12gauge
    edited January 2006
    yea thats thats how i got em wired.
    Shadow Inc records
  • PolkThug
    edited January 2006
    What is the gain set to on the Kenwood?
  • fortytha12gauge
    edited January 2006
    and about the jl i sent them to see if they would fix them. they wouldnt becouse of a few cosmetic scratches
    Shadow Inc records
  • fortytha12gauge
    edited January 2006
    i had the gain set a lil over half
    Shadow Inc records
  • MacLeod
    edited January 2006
    The gain is a little high, it shouldnt be over half but I still kinda think either something is wrong with the amp or the power running to the amp. Maybe you should dump that cap and see how things run. Caps are a scam.
  • PolkThug
    edited January 2006
    I had mine set at the 11:30 position (just under half). Hmm, I'd doublecheck your ground wire and power wires going to the amp. Make sure the ground wire makes a metal on metal connection and not a metal on painted metal connection.
  • fortytha12gauge
    edited January 2006
    i live in one of those towns were the cops harrass about dimming head lights and really the only other reason i bought it was becouse i had two amps hooked up before but i just put it in my dads truck for him. hahaha that was funny
    Shadow Inc records
  • MacLeod
    edited January 2006
    A good strong battery will stop your lights from dimming. A 450 watt amp is nowhere big enough to require a cap. Im running over 700 watts RMS and using the bone stock charging system with zero problems.
  • fortytha12gauge
    edited January 2006
    i just got a diff car and did the wiring. i had to scrape the paint of with a wire brush for it to wrk. the power cable should be fine its still fairly new.
    Shadow Inc records
  • fortytha12gauge
    edited January 2006
    beleive me its bad it a peice of junk 1990 sable
    Shadow Inc records
  • cam5860
    cam5860 Posts: 632
    edited January 2006
    What size power and ground wire you running? It's need to be at least 8 gauge.
  • neomagus00
    neomagus00 Posts: 3,899
    edited January 2006
    hmm... i'm not against caps, but you may wish to try it without... i'm pulling nearly 2kW, and i don't get headlight dimming at ALL...
  • fortytha12gauge
    edited January 2006
    ive got the beefy 4 gauge monster cable for the power and ground
    Shadow Inc records
  • Toxis
    Toxis Posts: 5,116
    edited January 2006
    I don't believe caps are a scam. I think they can mildly help but a better battery is definitely the better idea (other than upgrading an alternator). Not only does a cap help a little with the instant bursts but mainly I like them for the filtration they do to the power. If theres any kind of issues with your lines, they help clean the distortion out of the power which usually is a problem in a mobile system. But by no means do I think its necessary on a 450w kenwood.
  • fortytha12gauge
    edited January 2006
    i had 2 amps hooked up at once pushing a little over 1000 watts.And i bought the cap for that reason. im done with the other amp until i get a better one for my highs but i paid 160 for my cap and i dont want to waste it sitting around. You know wat i mean?
    Shadow Inc records
