Volume dial
Megalith
Would it be best to turn up the volume dial on the sub as high as you need it, or keep the volume dial only up to a certain point, such as 1/3 or 1/4, then increase the sub channel through your receiver.
I own a PSW12.
I own a PSW12.
Post edited by Megalith on
Set the volume dial on the sub where you like to listen and the sub setting is at "0" on the receiver. This allows for going either way with a remote.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
It's also recommended to set your receiver to 0, or perhaps even -1, or -2, so that the sub doesn't receive too "hot" a signal. The volume knob on the sub itself allows its own amp to drive it properly according to that dial setting. Bumping up the volume on the reciever throws the amp's settings and drives the sub too hard-possibly creating a bottoming out where the sub is trying to perform beyond its means.Current System:
CSi5-Center (for sale**)
FXi3-surrounds (for sale**)
Martin Logan Depth-Sub
B&K AVR 507
Pimare CD21-CD Player
Denon 1815-DVD Player
Panamax M5500-EX-Line Conditioner
