1.2 TL Crossover Upgrade
edited January 2006 in Vintage Speakers
I am getting ready to do this and need some help in answering a couple questions.
I identified all the components I want to change; the attached image shows them. Please make any comments or suggestions if I am missing something.
1st. Question; There are three capacitors that are different from the "normal"; These are the two big yellow (12uf each) and the small blue one that is at the top of the xover (.25uf). Is it ok to replace them with the same type as the rest? I guess this just shows my ignorance in electronics... and want to make sure I don't do something wrong; it is just weird to see those two big yellow and the blue that is in between them having the same value of 12 uF.
2nd Question: I looked in Partsconnexion.com and saw that there are several types of Solen caps; there are two (PB and PPE) that have only a small difference in price, but both are Metallized Polypropylene, 5%. PB are 400v and PPE are 630v; Which are the ones I should buy, or there is no difference?
3rd Question: how do I search for the two little silver mica things? Are these capacitors or what?
Thanks!!
SOPA
Post edited by Ricardo on
Welcome!
Welcome!
Welcome!
