Sub hooked up to CD Player
edited January 2006 in Electronics
I have my active sub hooked up to a second set of inputs on my CD player because my int. amp does not have sub outs. Works great, but I haven't quite figured out how and why it works. OK, here's my question -- does the amp play any role at all in the signal going the sub? The reason I ask is because when I turn up (or down) the volume on the amp, the sub's bass volume increases (or decreases) accordingly. Can anyone explain?
"God grooves with tubes."
Post edited by Early B. on
    edited January 2006
    I believe you mean 'outputs'. And that is an interesting note about how the sub's volume increases when you turn up the integrated's volume. Does that happen now that the sub is hooked up to the CDP?
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
    edited January 2006
    Hm...This is interesting. I see no way that the amp could affect the RCA's on the cd player, unless somehow they can affect RCA voltage.
Welcome!
Welcome!
