1.2 TL's Binding posts and SDA connection
Ricardo
I had this in mind for a while and today I did it.
Before:
Before:
SOPA
SOPA
Post edited by Ricardo on
First, get rid of everything old:_________________________________________________
For the SDA connection, since it's a pin/blade, only the pin is required; the blade goes to the negative binding post and is not required as long as you use a common ground amp. So I just used a binding post to replace the pin. I was lucky enough that the plastic washer (?) from the Dayton binding posts I bought fits perfectly in the whole of the original connector_________________________________________________
Next: enlarge the original holes to fit the plastics from the new posts; I also put some glue to fix the one for the SDA connection:_________________________________________________
Then fit the new posts, some sealant, and tighten them:_________________________________________________
The solder; YEAH BABY; ready to go for the crossovers_________________________________________________
Finished Product:_________________________________________________
Next? The crossovers; but I'll need some help here; I've got the schematic but I have no idea of what needs to be changed; all caps and resistors, and maybe the polyswitches? I'll get a picture one of these days of one crossover and see if I can guess on what goes and what stays._________________________________________________
Beautiful or what???_________________________________________________
Amplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96.
Hey Joe...that sig looking good...... just need to get everything hooked up and let us know what you think_________________________________________________
Yeah, I've got so many amps, eq's, mixers, crossovers, processors....I'm starting to wonder if the sound will actually GET to the speakers.Amplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96.
Looks nice, but two things. One you alluded to, if you ever wanted to run mono blocks, etc. with the AI-1, you can't. I don't see how this mod is any different than what was done to those beat to **** SDA's with the strange cable connections that just sold on eBay. That type of mod is not a good thing, IMO. The other, replace those stock jumpers.Political Correctness'.........defined
President of Club Polk -
F1nut wrote:Looks nice, but two things. One you alluded to, if you ever wanted to run mono blocks, etc. with the AI-1, you can't. I don't see how this mod is any different than what was done to those beat to **** SDA's with the strange cable connections that just sold on eBay. That type of mod is not a good thing, IMO. The other, replace those stock jumpers.
I thought about the AI-1 thing...and you really still can use it, though with a little extra work; you just need to get rid of the pin/blade connector; connect the cable from the pin to the "new" binding post, and the cable from the blade to the negatives, and voila.
Will change the jumpers; I just was too lazy to do it now_________________________________________________
